Go to Post Just be yourself, be honest, and most importantly, be present. The best role models are the ones you can relate to. - Jessica Boucher [more]
Unread 22-02-2016, 11:41
billay.jpeg billay.jpeg is offline
FRC #4053
billay.jpeg is an unknown quantity at this point
PCM not powering on
Recently we've had our pneumatic control module working when the robot turned on where the status light would blink green once turned on. Now there is no light when power goes through the module. We've checked the power going to it and it is sending a strong 12v and the 20a fuse on the PD board is good. Do we need to come to conclusion that it is busted or are we just missing something?
Everything is wired on the PCM including CAN wires, compressor, switch, and one solenoid; if that helps.
Unread 22-02-2016, 12:37
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: PCM not powering on
Same issue and our conclusion was... Its busted. A neighboring team gave us a new one which worked fine and we have since given them a brand new one.
