Go to Post “FIRST is your experience and you cannot let anyone else hinder what you can achieve.” - fuzzwaz [more]
Unread 22-02-2016, 11:23
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
First Stronghold Penalties
Attached is a summary sheet I created of the Penalties in First Stronghold.
On the first page I put match play penalties. On the second page are other penalties, legend, misc info, etc.
Note: This is for quick reference while Ref'ng, and should not be relied upon for any official purpose.
Unread 22-02-2016, 11:34
Re: First Stronghold Penalties
Some Drive Team questions that came to mind while creating the summary are:
1) You accidentally drive into the Opponent's Secrete Passage from the Neutral zone. What should you do?
a) Immediately exit back to the Neutral Zone
b) Continue on to the Opponent's Courtyard and hope that an Opponent's Robot is not in the way
c) E-stop your robot
2) Your robot became disabled over the Moat. The Draw Bridge or Portcullis is between you and the Secret Passage. You go on the field to remove your robot. What should you do?
a) Pick up the robot, and step over the Moat, and continue out the normal way
b) Ask the Head Ref for permission to step over the Moat when removing your robot
c) Pick up the robot, and carry it sideways away from the Draw Bridge/Portcullis, over the Low Bar, and over the Guard Rail.
d) Maneuver the robot off the Moat and onto the ramp. Remove it the normal way.
3) An Alliance partner has become disabled in your Secret Passage. It is also partially on the Courtyard. Unfortunately, you cannot pass the robot in the Secrete Passage. What should you do?
a) Drive around the disabled robot
b) Try to push the robot out of the way, but if you can't, give up.
c) Go to the Question Box, and ask the Head Ref for a replay
Unread 22-02-2016, 11:55
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Week 0, SOOOOOOO many yellow cards for walking over defenses.
Lots of teams using the secret passage illegally too.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 22-02-2016, 12:15
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
A If I have a boulder
B If I don't have a boulder
D
If I am reading this correctly you are saying that the a Red Robot got disabled in the red secret passage. You're options are A and B as long as you push it within the secret passage and not into the courtyard. No referee will give you C.
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 22-02-2016, 12:19
Originally Posted by MARS_James View Post
D
James is correct here--drive teams are specifically allowed onto the Defenses to remove a robot from them, if they need to, without fear of a yellow card. I would advise a referee that it looked like I needed to go onto the defense, so they knew I was doing that, but that shouldn't actually be necessary.
