pic: another view of Moose
Re: pic: another view of Moose
Very interesting arm.
What is the purpose of the "flipper doddles"; made up word for the aluminum pieces on top of your arm. Also, what does the drill-motor/red roller do? |
I'm not a part of the team but they probably extend so they can hang from the bar.
This year we tried to develop as much functionality into one main component as we could. So we ended up developing this arm. It helps us go over the categories A and C defenses, allows us to climb and score in the low bar, all weighing in at less than 25 lbs. So our practice robots arm can be our with oldie allowed e to use as a spare part. The whole arm cam be swapped in about 5 minutes if needed. Perfect for timeouts during elims. |
It is a linear actuator. However because the dart actuator is rather expensive (at least for us) we went out and got a linear actuator from princess auto down the road. It happened to be almost a perfect swap for a bag motor, has built in limit switches (which we re wired to go to the roborio, not the motor). Including the bag motor it cost us around $120-$130 canadian.
