Go to Post People don't have to "get" it. They just have to know about it. Once they know about it, then they come to it, experience it, talk to it, learn it, then get it. - Taylor [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 22-02-2016, 15:07
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: 2015 Compressor Fuse
R53 says the compressor can be controlled by a relay module
R66D allows you to put a Snap Action breaker in the relay module if powering the compressor
Not sure if that is what your are asking, but as in previous years, the compressor can be controlled by a SPIKE and gets rid of the problem described by the OP.
This is the way we will power our compressor.
The views expressed are mine and should not be construed to represent the views of anyone else.
  #32   Spotlight this post!
Unread 22-02-2016, 15:25
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Not really, but thanks for answering. I want to avoid additional electronics if not necessary.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
  #33   Spotlight this post!
Unread 22-02-2016, 15:28
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Originally Posted by RyanN View Post
R48 sort of hints to the fact that it is legal in stating that the PCM can have a 20A breaker.
Yes, it is legal to connect the PCM to a 20 amp Breaker, and not the PCM connection on the PDP.
The Robot can have One and Only One compressor. R48 says "PCM - with compressor". If the compressor had to be connected to the PCM at the PCM connection, then it would be impossible to also have another PCM with a compressor connected to a different 20 amp circuit.
In addition, you are not required to use the PCM to control your compressor. You could use a Spike Relay as rsisk mentioned. Again, if you had to use the PCM, then there would be no reason for R66-D.
  #34   Spotlight this post!
Unread 22-02-2016, 17:23
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
I don't see anything in the manual that requires the PCM to be powered by the connection at the end of the PDB.
I don't see anything preventing power from coming from a PDB circuit with a 20AMP breaker.
And finally, don't see anything about it on the inspection worksheet.
Unless directed otherwise by FIRST, I would pass it at a competition.
