Go to Post I believe you have the right to develope your own opinion. I would suggest it be based on actual experience and facts. - Mike Copioli [more]
Unread 14-02-2016, 13:51
Allthatslack Allthatslack is offline
None #1389
Allthatslack is an unknown quantity at this point
New radio
Hello.
My team and I have been notice that our radio is being a little annoying because it is losing communications a lot. I was just wondering if this has been happening to other teams?
Unread 14-02-2016, 14:00
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Re: New radio
Originally Posted by Allthatslack View Post
Hello.
Are you losing the Wifi connection or the Rio communication on the Driver Station? If the latter, check out this thread where we encountered the same problem: http://www.chiefdelphi.com/forums/sh...d.php?t=142651
Unread 14-02-2016, 16:43
jojoguy10's Avatar
jojoguy10 jojoguy10 is online now
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
Re: New radio
Our team (and a lot others) had this problem too. FIRST acknowledged it in Update 08, and released the update to the FRC Radio Configuration in Update 10.
I would download the new FRC Radio Configuration utility (HERE) and re-flash the new firmware on your radio and see if that works.
If that doesn't end up working: we moved the ethernet connection to the other port (the port closest to the power connector), and that fixed it (according to Team Update 08)
Unread 22-02-2016, 16:20
Ichlieberoboter's Avatar
Ichlieberoboter Ichlieberoboter is offline
Awards and Programming
AKA: Maria Valentini
FRC #2499 (Industrial Revolution)
Ichlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud of
Re: New radio
Our radio had been cutting out when we drive because the voltage has been dropping from 12 volts to 8 volts which apparently is not enough for the radio to stay connected. We use a lot of voltage because we are using all six cims. We had to add more cims to our drive train so the original motors don't overexert and switch the cims used for our launcher to mini cims. We aren't 100% sure this will work but we are trying it out currently.
Team 2499-Industrial Revolution
2015 Lake Superior Regional Judges Award
Head Programmer Chairman's Award Presenter Awards Submitter Electrical Team Website Designer Strategy Team
Unread 22-02-2016, 16:33
kdavidson kdavidson is offline
AKA: Ken Davidson
FRC #0173 (RAGE)
kdavidson is an unknown quantity at this point
Re: New radio
Is your radio power coming from the Voltage Regulator Module (VRM)? If not, it should be. That module puts out a steady 12 V even when the input voltage drops below 12 V.
Ken
Unread 22-02-2016, 16:34
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: New radio
Do you have your radio powered from the VRM? According to the user manual, it should work all the way down to 5V input. If your powering it through the VRM, it shouldn't be dropping out on you. On the other hand, if it's powered straight from the PDP (which is not legal), it will drop out on you.
2016: Lake Superior WFFA
