Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
Unread 22-02-2016, 16:58
Priopelle Priopelle is offline
FRC #5658
Priopelle is an unknown quantity at this point
Limit Switch Help
I have coded our arm to extend, but I do not know how to program limit switches. Here is our arm extend code http://imgur.com/R1yyDFW
Unread 22-02-2016, 17:02
Re: Limit Switch Help
What motor controllers are you using?
Can you post a picture showing how your limit switches are mounted?
Unread 22-02-2016, 17:48
FRC #5658
We are using a spark motor controller and here are the two limit switches
http://imgur.com/a/Pj01W
we would like them so you cant go too far either way
Unread 22-02-2016, 17:57
I believe you can wire the limit switch directly to the Spark, and the Spark will handle it for you. No coding necessary.
I can't be sure, but it looks like the limit switch is in harm's way. You don't want to do that.
Read this thread:
http://www.chiefdelphi.com/forums/sh...40#post1539040
Unread 22-02-2016, 18:05
FRC #5658
ok thank you
Unread 22-02-2016, 20:08
Do yourself a big favor and read these before proceeding:
http://www.revrobotics.com/wp-conten...1200-NC-00.pdf
http://www.revrobotics.com/wp-conten...1200-UM-00.pdf
