Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Unread 22-02-2016, 17:06
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Weird roboRIO to Laptop Connection Problem
So I'm having a weird problem with the roboRIO that I'm hoping someone can help me solve. Last night, the robot was working fine while tethered to the laptop via Ethernet. When I came in today and tried to connect, however, it would not connect to my laptop. Further testing revealed that the roboRIO is communicating with the radio (it is getting an auto-assigned IP address), but not with any laptop (I have tried multiple). When I hardwire the roboRIO directly to the laptop via Ethernet, the comm and data transfer lights on the Ethernet ports stop lighting up. I can ping the roboRIO from my laptop and it will respond, but no other program recognizes it (e.g. Driver Station, Imaging Tool). Connection over USB doesn't work either. Any suggestions?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 22-02-2016, 22:35
Re: Weird roboRIO to Laptop Connection Problem
Did someone or something turn your Windows firewall on?
Unread 25-02-2016, 00:17
Ari423's Avatar
FRC #5987 (Galaxia)
No it turned out to be some problem with the code for the NavX. I disabled that and the problem went away. I plan on troubleshooting more on our spare roboRIO before our first competition.
2013: Programmer
Unread 25-02-2016, 22:57
Are you using the latest NavX driver?
Unread 25-02-2016, 23:01
Ari423's Avatar
FRC #5987 (Galaxia)
Yes, just downloaded it from their website last week.
2013: Programmer
