Go to Post Automonous - n. the frequent sound made by a team member not wearing a watch. ex: Do you know automonous? - Cynette [more]
Unread 22-02-2016, 16:14
pujan824 pujan824 is offline
AKA: Pujan
FRC #4939 (AllSpark9)
pujan824 is an unknown quantity at this point
HELP: Voltage Drop
When testing our robot, we were getting a voltage drop to 6V when going over the obstacles. When going over the carpet we have been dropping voltage to 9V.
Our robot has 6 8" pneumatic wheels powered by 2 cims in a toughbox mini each controlled by a talon srx
It has 2 window motors for lifting our arms each controlled by victors
2 mini cims for shooting each controlled by talon srx. (we are planning to swap these out for banebots RS-775 or 775pros )
We also have noticed the front CIMs on our drivetrain getting really hot.
Our drivetrain does not have the center wheel dropped.
Currently we do not have the time to create a center wheel drop.
Unread 22-02-2016, 16:15
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: HELP: Voltage Drop
What's your battery voltage when you're not moving (idle)?
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 22-02-2016, 16:16
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
With all these topics on power draw I am really surprised to not see any current readings from the PDB. With voltage and current it would be more clear what is drawing all that power.
Unread 22-02-2016, 16:17
AKA: Pujan
It's at 12.5 V
Unread 22-02-2016, 16:18
AKA: Pujan
We just checked and its from the drivetrain cims. But the front cims are drawing the most power while the back cims aren't anywhere near that
Unread 22-02-2016, 16:45
techhelpbb's Avatar
So by 'front CIMs' you mean that in if you look at the top of the robot with 2 CIMs in the ToughBox Mini you see this issue only on the CIMs closest to the front of your robot?
Are the wires to the 'rear CIMs' much longer than the 'front CIMs'?
Unread 22-02-2016, 16:48
kdavidson kdavidson is offline
AKA: Ken Davidson
FRC #0173 (RAGE)
kdavidson is an unknown quantity at this point
Are both SIMs in each Toughbox pair being driven in the same direction? If they are fighting each other, I wouldn't be surprised to see this. We always run one at a time as a first test to make sure they are going the right way.
Ken
Unread 22-02-2016, 17:01
With what gear ratio?
Please post the actual numbers, and include what command was being given to the CIMs.
Did you guys do any calculations before selecting wheel diameter and gear ratio?
Unread 22-02-2016, 17:19
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I would say the most likely issue is using 6 pneumatic wheels without a drop center. That's a whole lot of scrub when you try to turn, and that will eat your battery like you wouldn't believe.
2016: Lake Superior WFFA
Unread 22-02-2016, 17:22
techhelpbb's Avatar
Is there a troubleshooting flow chart for this?
I mean I can easily find 6 topics on related issues.
Maybe it's time someone makes a troubleshooting flow.
Unread 22-02-2016, 17:45
This happens almost every year right toward the end of build season.
Maybe the kit of parts should contain a big warning notice on day-glo orange card stock about improper drivetrain gear ratios and oversquare skidsteer bots.
Unread 22-02-2016, 17:51
techhelpbb's Avatar
Maybe if GDC says those are the only types of robots allowed in a team update enough people will read that joke enough to get the idea not to do it Reverse design psychology.
In fairness since it happens over and over probably time to crack out Draw.io and make a flow chart.
At least to save myself the CSA size migraine March 4th.
Unread 22-02-2016, 18:29
AKA: Pujan
Yes. That's the issue. And the wires to the rear cim is about the same length as the front cims
Unread 22-02-2016, 18:30
AKA: Pujan
Ken
We have tried that and found that they aren't fighting each other.
Unread 22-02-2016, 18:32
AKA: Pujan
No we haven't done any calculations but the lead member for team 1241 told us this should be fine for our purposes.
