Go to Post I want my students to learn passion. I want them to care so much about what they are doing that they infect other people with it... be that FRC or anything else. - marshall [more]
Unread 22-02-2016, 19:32
The Ginger's Avatar
The Ginger The Ginger is offline
#GingerPower
FRC #5464 (BluejacketRobotics)
Team Role: Driver
Rookie Year: 2015
The Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud of
Electrical chain hacks
Hi CD, my team is wondering if anyone has found or has ideas about how to stiffen an electrical chain so it still will bend in one direction but does not flex so much in the other. (when you have a section about 7 feet long it gravity is relentless) If you got an idea fell free to say it, no matter how stupid or genius it may be.
-thanks, The Ginger
"The difficult we do today, the Impossible tomorrow, Miracles by appointment only."
"Theory is a nice place, I'd like to go there one day, I hear everything works there."
"Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot."
"I have approximate knowledge of many things."
Unread 22-02-2016, 20:37
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Electrical chain hacks
Not sure what you're trying to do, but there are some black links which come in the KOP which can act in the way you're talking about and you can run the wiring through them.
Unread 22-02-2016, 20:46
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
I expect the OP is trying to come up with a scheme to use chain in order to grab the bar in order to climb.
Jim
Unread 22-02-2016, 21:56
The Ginger's Avatar
#GingerPower
Team Role: Driver
Rookie Year: 2015
correct, our tape measure thing did not work so we made a system to extend a electrical chain from the KOP, but the when you are trying to stick a length of it 7 feet into the air it tries to flex back onto its "rigid" side.
