Go to Post Easy, we use Magic. Your team wasn't given that in the kit? - Michael Hill [more]
Unread 22-02-2016, 20:43
Kevin Pai's Avatar
Kevin Pai Kevin Pai is offline
FRC #5964 (Praetorians)
Rookie Year: 2015
Kevin Pai is an unknown quantity at this point
2 Autonomous Codes for Competition
Hello everyone, our team was wondering if we could switch between 2 autonomous codes before each round of the competition depending on what defenses that we want to breach. If so, how do you switch between the 2 codes on the driver station without using the USB to Roborio cord?
Unread 22-02-2016, 20:46
Re: 2 Autonomous Codes for Competition
Answer of switching auto codes:
Nothing prohibits this.
Answer to the rest of the question: You could use a switch on the robot, a switch on the driver's station, and have your code read what the switch is set to right at the start of auto.
Unread 22-02-2016, 20:56
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
https://wpilib.screenstepslive.com/s...smartdashboard
We are using a Sendable Chooser, which you can learn about in the link above. Essentially, you can add different auto options, and then in the setup before a match, you choose whatever option you want from the SmartDashboard. Hope this helps!
