#16
Re: HELP: Voltage Drop
They should definitely do that. Would help a lot of teams that made the same mistake as us
#17
You are not clear if you have 4 CIMs or 2 CIMs. I assume 2 CIMs PER SIDE is your configuration.
Are all 3 wheels & all CIM on each side drive train mechanically coupled (chain, belt, gears) such that rotating one wheel rotates all wheels and all motors? Or do you have a different configuration (e.g. front wheel driven by 1 CIM, back & center driven by another CIM)? All ratios from motors to wheels (and size of wheels -- but we already know that 8") are also needed to answer questions intelligently. Dr. Joe J. |
#18
As to the 9V when you are just on carpet, this is not turning right? If it is turning and you have not lowered the center wheels as you have said, then this is just normal behavior, but if it is going straight, then it could be that your pool noodles are not consistent and as a result they give you different circumferences for each wheel. Again, with such a high CoF, your motors are busy turning electrons into heat just due to these variations in wheel circumferences. What to do? Well, put your robot up on blocks and see what the current draw is. It might be that you have losses generally that are causing you to start in a current hole to begin with. Look for tight belts, sticky bearings, mis-aligned axles, something rubbing against the wrong bit of a bearing (you want your wheel's thrust load to go into the inner race of the bearing not the outer race or the shield). Assuming you can get the off the ground current to something manageable, then it is time to get real about wheels. 6 wheel drive with these tires and no rock from lowering the center wheel is a slow motion train wreck. You have to fix that. Go back to air on the center tire and over inflate that tire, put some tape over the front or rear (or both) wheels) to make them less grippy, switch to another wheel style for the front or back (or both) wheel, figure out SOMEWAY to give yourself some rock in your chassis. Good luck... Dr. Joe J. |
#20
How much pressure did you have them inflated to? Maybe it was too high or too low? Also, there are tubes and there are tubes. Not all are created equal. If you search around a bit (or even ask ChiefDelphi) you can find thicker tubes that will be less susceptible to popping. Good luck, Dr. Joe J. |
#22
Also, can you get us some photos of the hub and tire you are using (get close ups of the tire so we can read the make & model numbers)? Perhaps you can switch to a tougher tire that will fit on the hubs you are using? Dr. Joe J. |
#24
We have custom hubs made. I will upload a picture later today |
#25
Here's what I think you might want to do: Take advantage of the fact that not all 8" wheels are actually 8" in diameter to give yourself some rock and also to replace one of the sets of wheels in contact with the carpet with something less grippy. Path 1: Buy tires like this one from AndyMark or this one from VexPro and replace the center tires. If these tires are a little bigger in diameter than the Princess Auto tires, then hopefully it will give you enough rock.Path 2: Buy Omni Wheels like this one from AM or this one for Vex. Replace the middle wheels if the diameter is a little bigger than the Princess Auto Tires, replace either the front or the back if they are smaller. As to front or back, experiment a little, it depends on where your CG is located and how you climb. You are trying to get only two adjacent Princess Auto Tires to touch the floor at the same time.Good luck. Dr. Joe J. |
#26
You are right.
Let me vent a little here and just say that making custom hubs is probably something teams should think long and hard about before deciding to go down that path. There are so many really great wheel/hub options to choose from. Unless you are getting a lot of bang for the buck (broadly construed not actual $s), I just don't think this is the path for 95% of teams out there. This from a guy who has made robots with many many custom hubs and custom wheels and custom tracks and custom FILL IN THE BLANK. But I'm older and wiser these days. There are so many places to innovate in FIRST. Spend your creativity bucks in areas where it's going to get you significant advantages. For the vast majority of teams that isn't in making custom hubs for 8" wheels. Calling 'em as I sees 'em. Dr. Joe J. |
#29
We ran into a similar issue yesterday, but the source of the issue was easy to identify and resolve.
We were dropping the voltage on our battery to <8.5v every time we did a point turn/pivot. Driving straight kept the battery above 12v. This was obviously a scrub issue. We are running a typical WCD with 8" pneumatic wheels, thus the scrub should not have been too great, but it was. Why??? During early practice session, the students felt it was beneficial to lower the pressure in the center tires to help gain traction going over the Rock Wall. Lowering the pressure to ~0psi basically renders a WCD to be just a 4 wheel tank steer. We re-inflated the center tires and our voltage drop on point turns returned to normal, around 11.5v. With the additional practice time we had put in, our driver also had figured out how to transition the Rock Wall without the need to have "high traction/ low pressure" center tires. Now what bothers me with the OP's issue is how two motors on the same transmission could have such a huge temperature difference. Are you controlling the ESC's via "Y" cables, or discrete PWM outputs from the RoboRio? |
#30
