Go to Post I can't wait till FIRST starts giving anti-gravity kits inside the kit of parts. - Rob Colatutto [more]
Unread 22-02-2016, 23:38
itwasntme455 itwasntme455 is offline
AKA: Brandon
FRC #4791 (Pandroids)
itwasntme455 is an unknown quantity at this point
Help programming pneumatics
This is our teams first time using pneumatics. We have everything hooked up but are having issues with the programming part using LabVIEW. We would like the piston to extend when button "A" is pressed and retract when button "A" is released. How would we achieve this. Thanks in advance!
Last edited by itwasntme455 : 23-02-2016 at 00:22. Reason: enter programming program
Unread 23-02-2016, 00:05
Noviv's Avatar
Noviv Noviv is offline
FRC #1477 (Texas Torque)
Noviv is an unknown quantity at this point
Re: Help programming pneumatics
You will just need to set the value of the pneumatic to one position while the button is being pressed, and the other when it is not.
Psuedocode:
if (A button is pressed) {
    pneumatic.set(on);
} else {
    pneumatic.set(off);
Java Single Solenoid:
Solenoid solenoid = new Solenoid(port);
if (operator.getRawButton(1)) {//example
    solenoid.set(true);
} else {
    solenoid.set(false);
DoubleSolenoid solenoid = new DoubleSolenoid(portA, portB);
    solenoid.set(DoubleSolenoid.Value.kForward);
} else {
    solenoid.set(DoubleSolenoid.Value.kReverse);
getRawButton(1) should be mapped to the A button on Xbox controllers. Switch it to getRawButton(2) for Logitech controllers.
Unread 23-02-2016, 00:21
AKA: Brandon
How about in LabVIEW?
Unread 23-02-2016, 02:02
Noviv's Avatar
Sorry, my team has only used C++ and Java. Here are a few links that might be helpful:
http://www.chiefdelphi.com/forums/sh...ad.php?t=73821
http://www.team476.com/wpimages/wp1798b5a5_05_06.jpg
http://www.chiefdelphi.com/forums/sh...ad.php?t=90429
I hope this helps!
Unread 23-02-2016, 03:26
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
Like so:
In the false state of the case structure in Teleop, the solenoid must be set to reverse instead of forward. Additionally, in Begin, make sure your PCM ID and solenoid channels match how you wired your robot; the forward channel is the channel wired to the end of the solenoid connected to the part of the piston further from the rod, while the reverse channel should be set to the closer end. If you're unsure, just guess and switch it if it's backwards.
Last edited by thatnameistaken : 23-02-2016 at 03:35. Reason: Reworded to flow better
Unread 23-02-2016, 09:37
Here's another example
