Go to Post I thanked the tradesmen on our team the same way i do ever year with a handshake and a "thanks for helping us guys", - Mike Schroeder [more]
Unread 22-02-2016, 21:57
Sjtumlin16 Sjtumlin16 is offline
FRC #4521
Sjtumlin16 is an unknown quantity at this point
Launchpad control panel outputs help
How would the labview code be made so that if a limit switch is pressed a light turns on on the control panel which is using a Launchpad, from what i can see the joystick output block only allows 1 non-addressable output to be turned on.
Thanks.
Unread 22-02-2016, 23:28
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Launchpad control panel outputs help
The joystick output block takes an array of Boolean values to define the output state on the TI LaunchPad.
Here are a couple of examples of setting the outputs with arrays:
Name:	Launchpad Switch Examples.png
If you have a couple of switches, you could do something similar to below:
Name:	Launchpad Switch Example 2.png
Note that in my examples above everything is zero indexed (the output names I set start with 0). On the TI LaunchPad documentation the outputs are 1 indexed (the output naming start with 1).
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 23-02-2016, 06:15
FRC #4521
Thank you w200999! That's exactly what I needed.
