Go to Post To change culture, you're going to have to get people to listen. - Yipyapper [more]
Unread 23-02-2016, 06:30
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
NetworkTables rPi
Hi!
Is it possible to install NetworkTables(c++) for our pi? We want to run c++ openCV scripts and use NetworkTables to grab the values and bring them back to the Rio.
Thanks!
Unread 23-02-2016, 06:42
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
It is possible, I believe. We run it in Python with the pynetworktables library, so I'm sure there's one for C++.
ORB Haow!
Unread 23-02-2016, 10:58
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
Re: NetworkTables rPi
https://github.com/PeterJohnson/ntcore
Unread 23-02-2016, 18:57
axton900's Avatar
Rookie Year: 2015
That requires the use of toolchains which is not supported by Raspbian. Is there any other way?
Unread 23-02-2016, 23:42
virtuald's Avatar
RobotPy Guy
I would recommend searching these forums, I'm sure someone else has done it.
Unread 27-02-2016, 13:21
axton900's Avatar
Rookie Year: 2015
If anyone knows how, if they could explain the process of doing this or point me in the right direction, then I would be very grateful!
Thanks!!
Unread 27-02-2016, 13:33
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Thanks!!
I was able to do it a while ago. As long as you are running the lastest raspbian, it should have GCC 4.9, and compile correctly. It just takes a while. You might have to use cmake, I don't remember.
Team 4488 - Mentor 2013-2016
Unread 27-02-2016, 13:37
simon-andrews's Avatar
simon-andrews simon-andrews is offline
FRC #4761 (Robockets)
Rookie Year: 2015
simon-andrews is an unknown quantity at this point
As Thad said, you can compile directly on the Raspberry Pi. CMake is definitely the easier option.
Should be something like:
cd ntcore
cmake .
make
sudo make install
Then when you compile you would add the "-lntcore" flag to G++.
I remember Java giving some trouble with compiling. If it does run "cmake . -DWITHOUT_JAVA=true" instead.
GitHub | StackOverflow
Unread 27-02-2016, 17:37
axton900's Avatar
Rookie Year: 2015
Thanks for the help! We really appreciate it!
Unread 27-02-2016, 22:54
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
There is a version of ntcore built for the Raspberry Pi 2/Debian for use with GRIP. You might want to look at:
https://github.com/WPIRoboticsProjec...eases/tag/v0.1
Unread 01-03-2016, 15:33
axton900's Avatar
Rookie Year: 2015
I'm running into an error after installing and compiling and using the -lntcore prefix but I'm getting the error, "error while loading libraries, libntcore.so.1 cannot open shared object file: No such file or directory" What should I do?
Unread 05-03-2016, 10:42
Rookie Year: 2015
You need to append /usr/local/lib to your library path. CMake installs libntcore.so to /usr/local/lib which is not on the library path by default. This answer on StackOverflow answers the question better than I can.
Sorry for the late response and I hope this helps!
Unread 05-03-2016, 10:49
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I have a quick question for you. Depending on your response, I might have an alternate solution that works well for us.
I believe I know the answer, but the question is, are you running your RPi on the robot? In other words, are you doing your vision processing on the RPi on the robot.?
Unread 22-03-2016, 17:02
axton900's Avatar
Rookie Year: 2015
Yes, yes we are. We seemed to have it working now but we are eager to hear your alternate solution Sorry for the late response!!
