Go to Post Remember, only YOU can set a good examples for rookies to search CD first before asking questions or responding!! - Foster [more]
Unread 23-02-2016, 07:27
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
Re: USB Cameras with roboRIO
Originally Posted by cbf View Post
Most USB cameras will work. Are you by any chance using the SmartDashboard? If so, then try the Labview ("default") Dashboard and set it to USB Camera (HW). Once you get a video feed there, you can then switch the SmartDashboard.
This is due to a bug in the WPILib CameraServer class (that's been there for at least two years). We made our own version that fixed the bug.
Thanx for this note. The camera is much more important this year than last year. Last year we just gave up on the HD-3000 usb camera. This year we switched to a Logitech Usb camera and we get consistent image exposures.
We find that having to go to the Default Dashboard to get the video feed going (via USB Camera HW), then switching to SmartDashboard annoying. One of those things that we would rather not have to do while frantically setting up for a match.
We are using USBcamera class and code in C++.
