Go to Post Be the change you want to see. - staplemonx [more]
Unread 23-02-2016, 12:31
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: OM5P-AP radio failing... no lights
Originally Posted by PhilBot View Post
The only thing we could think of was that we were getting spikes on the 12V line, but this seems very unlikely.
My first thought is that it could be your VRM. Is there a log of VRM voltage anywhere?
Unread 23-02-2016, 14:15
No
Unread 23-02-2016, 14:19
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell will become famous soon enoughdroswell will become famous soon enough
We have the same failure - drove our bot over a defense and it shut off. We thought a loose connection as well, but looked and it was connected. Unplugged, and plugged back in.
No lights. Checked and found 12V on the barrel connector. Checked again - still no lights. We bought this second one from Andymark and put an RMA in. Hopefully this isn't a common issue.
We've wrapped our new radio in foam to protect against shock, but the airflow will be reduced. May have to get creative...
Unread 25-02-2016, 13:35
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Well, we lost another radio.
The build team swapped out the VRM (in case that was the problem), and proceeded to drive for a while, until the next major bump caused the radio to lose it's lights. Now it's dead.
We're now on our 6th and final radio (I don't even know where they all came from, but they must have been a week one bulk purchase).
That's 4 dead radios (no lights) and one that won't configure properly.
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 25-02-2016, 14:29
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We have one radio that is died in a similar fashion during our practice last night. Haven't found a root cause.
Unread 26-02-2016, 23:45
Engineering Coach
I took apart our radio that wasn't powering on to see if there was anything I could noticeably see as a problem. There are only two screws under the front foam feet. The screws don't need to come all the way out just loosened then the top is able to pop off easily. There wasn't any heavy swarf or any noticeable burnt components. There are three antennas in the radio one along the front and two along the left side when looking at from the rear.
I had to cut/pry some adhesive off to remove one of the antenna connectors to get to the bottom of the board pair (their are two boards, one main board and daughter board in a slot). Once I did this I was going to check the voltage at the input barrel but when I plugged it in the light just came back on. Not sure what happened but it doesn't seem like dead radios are dead forever which is a good sign. I still worry about using this one on our competition robot.
In summary opened it up and after plugging it in it started working again without me intentionally fixing anything.
