Go to Post I think I'm going to need a 12 step program to help cure me from my Cryptic Dave Lavery Chief Delphi Post Analyzation Disorder I got goin' on here. - Elgin Clock [more]
Unread 23-02-2016, 15:55
2393 Safety 2393 Safety is offline
AKA: Madelyn Fahhoum
FRC #2393 (Robotichauns)
2393 Safety is an unknown quantity at this point
1/11-1/15 2393 Safety Topics
Monday 1/11: When inclement weather occurs, be sure to wear supportive shoes with good grip to avoid falls.
Tuesday 1/12: Stop work prevents an incident, damage, or injury from occurring, no matter how minor or serious. Any one can call stop work. Safety is everyone's responsibility.
Wednesday 1/13: To avoid straining your back when you are lifting make sure you keep a wide base of support, squat, keep good posture, slowly lift, hold it close to your body, use your feet to change direction, lead with your hips, and set down carefully. Never lift heavy objects above your head and avoid twisting your body while lifting or holding a heavy object.
Thursday 1/14: Be careful not to trip or fall when there are spills of walking surfaces, loose mats or rugs, poor lighting, walking areas are uneven, or there is snow, ice or rain outside. Use handrails when they are available and don't walk with both hands full.
Friday 1/15: There are four main types of fire extinguishers. Class A extinguishers are for ordinary combustible materials such as paper, wood, cardboard, and most plastics. Class B extinguishers are for fires involving flammable or combustible liquids such as gasoline, kerosene, grease and oil. Class C extinguishers are for fires involving electrical equipment, such as appliances, wiring, circuit breakers and outlets. Never use water to extinguish class C fires. Class D extinguishers are commonly found in a chemical laboratory. Our fire extinguisher is a class A, B and C extinguisher. When using a fire extinguisher remember PASS, pull, aim, squeeze and sweep.
