Go to Post I hope that kids will stop asking us if we build Battlebots and start asking us if we build Transformers. To that, I will answer with a resounding yes. - Madison [more]
Unread 23-02-2016, 16:29
jessemichael jessemichael is offline
jessemichael is an unknown quantity at this point
Pneumatics problems
We have an issue where the pneumatic solenoid valve won't move when we press the button on the controller, the respective side of the solenoid lights up a solid orange but the valve does not move and send air to the opposite tube. We are using a double solenoid in which the intake is in port one and the exhaust is on ports 4 and 2. The program is the same as on the wpilib website.
Unread 23-02-2016, 16:58
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Pneumatics problems
Is it by chance a 24 volt solenoid being powered at 12 volts?
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 23-02-2016, 17:03
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Please post what model solenoid you are using. The part number is normally printed on the side and usually have the voltage needed as part of that number..
Also how much pressure are you using? Solenoids require a minimal amount of pressure for them to actuate. Many of the Festo used in FRC need 30psi present to actually shift.
Good luck this year.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 23-02-2016, 17:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We had this or a similar issue a few days ago.
Most of the solenoids used in FRC are air-piloted. This means that without air pressure, the valve does not move. We are using the Vex manifold-based solenoids for the first time, and one of our cylinders is single-acting. The port intended for the return stroke was "creatively plugged" in such a fashion that the supply air was vented directly to the atmosphere, apparently dropping the supply pressure at the manifold below the pilot threshold. When they switched to separate solenoids, things worked fine. We are again working with the manifold-mounted solenoids.
Unread 23-02-2016, 17:13
Alright, thanks for replying but, I guess one of our guys changed the voltage maybe and that got it. So, it works now but thanks for the input
