Go to Post These are words on a computer screen, please stop giving the text on this screen such incredible power over how you feel. - Stephen Kowski [more]
Unread 23-02-2016, 12:17
tedlasai tedlasai is offline
FRC #2996
tedlasai is an unknown quantity at this point
Talon SRX PID tuning
I am working two shooter motors that are used to throw the ball out. One of the shooters motors has perfect PID values at P=5 I =0.01 D =2. We have tried these values on the other motor but it shoots up very fast. The values we were playing with last night gave us p=4 i =0 d=2. This produced a steady oscillation under the target. However, when we increased the i to match the target line it just shot of. Any amount of I caused the motor to shoot off really fast. We are setting the i small at the beginning like values of 0.01 or 0.001. Is there an explanation for this?
Sai
Unread 23-02-2016, 12:37
Re: Talon SRX PID tuning
Do you want the motors to run at the same speed? If so, you can set one of the Talons to be a "slave" to the other as a "master", and run the closed-loop control on only the master. This assumes that you're controlling them over CAN.
Unread 23-02-2016, 14:07
FRC #2996
No, they will have to run at different speeds. Do you have an idea of why the Integral gain of 0.01 or 0.001 causes the speed of the motor to accelerate like crazy.
Unread 23-02-2016, 14:08
Jared Russell's Avatar
Taking a year (mostly) off
Read the Talon SRX Software Reference Manual very closely so that you understand what exactly each of your gains does.
In particular, there is a very useful example in this document to help tune velocity PID loops.
Unread 23-02-2016, 16:50
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Also there github is very helpful with actual code.
https://github.com/CrossTheRoadElec/...0Closed%20Loop
The sooner we get behind schedule, the more time we have to catch up.
Unread 23-02-2016, 17:08
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
This may also be useful
http://www.chiefdelphi.com/forums/sh...ight=Bang+bang
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 23-02-2016, 17:16
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Also read up on the SRX "IZone", sounds like you could use that feature to limit the I accumulated when out of zone.
I had a tough time with getting the SRX units straight. It is all in the manual, but I'm and engineer, and I don't read manuals.
OMAR has spent a good amount of time getting all of the options documented, and giving good examples. We shoot at 9000 rpm, and the control on the SRX is simply unbelievable is a sub $100 controller.
Unread 29-02-2016, 22:12
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
Rate PIDs are a little weird- you actually only tune I and P. You can think of the reasoning as "I'm tuning for the derivative of position, so all the constants act as if they were derived: in a rate PID, I acts like P, P acts like D, and the D value is, afaik useless
Unread 29-02-2016, 22:14
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
I'd recommend using the feedforward (F gain) in the talon's PID. You can read about it in the talon documentation.
With that, I've been able to get very solid shooter wheel velocity control with just P and F -- no integral or derivative.
Head Programmer / Driver
