Go to Post Nothing you learn can truly prepare you for everything that comes your way. - sciguy125 [more]
Unread 23-02-2016, 18:15
GuardedAirplane GuardedAirplane is offline
FRC #3600
GuardedAirplane is an unknown quantity at this point
Question Smart phone use on robot
Is it legal to use an iPhone as an ip camera over the robot lan? The iPhone would not be using cellular or performing any other actions than streaming live video to our team's drive station.
Unread 23-02-2016, 18:48
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
Re: Smart phone use on robot
Do you have a way to make a wired LAN connection?
Unread 23-02-2016, 18:57
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
I was under the impression that COTS computing devices could run off their own internal batteries. I would be more concerned about a wired LAN connection to an iPhone, it can be done using an Apple branded USB to Ethernet adaptor, a powered USB hub and an Apple Female USB to Lightning adaptor. I'm unsure of the reason the hub is necessary, but I imagine it is to supply input power since ethernet doesn't carry enough on its own. Seems like a lot of work when a USB Webcam plugged into the roboRIO should accomplish the same thing.
Update:
R31 at the very end: "Additionally, batteries integral to and part of a COTS computing device or self-contained camera are also permitted (e.g. laptop batteries, GoPro style camera, etc.), provided they’re only used to power the COTS computing device and any peripheral COTS USB input devices connected to the COTS computing device and they are securely fastened to the ROBOT."
This would indicate that an iPhone on board is not limited by it's battery. You may have to prove that it isn't interfacing with any wireless networks and of course use the method described to connect it to LAN.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 23-02-2016, 19:32
FRC #3600
Just to clarify, the I was envisioning the iPhone connect to the wifi connection of the robot radio using a static ip address just like a normal ip camera. Is that ok?
Unread 23-02-2016, 19:39
No that's not legal. The only wireless connection allowed is the robot to FMS
Unread 23-02-2016, 19:42
Why_A_Username?'s Avatar
Why_A_Username? Why_A_Username? is offline
AKA: Jacob Pilch-Bisson
FRC #2910 (Jack-In-The-Bot)
Team Role: CAD
Rookie Year: 2015
Why_A_Username? has a spectacular aura aboutWhy_A_Username? has a spectacular aura about
I'm fairly sure you can turn off wifi on the phone and connect via USB to lightning charger. not 100% on that though.
"I don't remember how to make that! It came to me in a dream, and I forgot it in another!" -Professor Hubert Farnsworth
"The only difference between science fiction and science is time"
-Dean Kamen
Unread 23-02-2016, 20:27
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Also realize that iPhones cost more than $400 at retail, and would not be legal under R11. There are smart phones that retail under $400 that you could use. The better solution if you just need a camera would be to get an IP or USB camera.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
