Go to Post I check Chief Delphi more often than I check Facebook and Twitter combined. It's probably unhealthy actually... - Ginger Power [more]
Unread 23-02-2016, 18:20
SandraM6046's Avatar
SandraM6046 SandraM6046 is offline
FRC #6046 (King Tech)
Rookie Year: 2016
SandraM6046 is an unknown quantity at this point
Question Numbering on Bumpers
My team is having trouble figuring out how to put our team number on our bumpers as nothing seems to stick to the fabric. We are planning to use white spray paint, is this legal and are there any alternatives?
Unread 23-02-2016, 18:23
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Numbering on Bumpers
We ironed ours on. Not sure where we got the iron on numbers, as I didn't do that part.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 23-02-2016, 18:28
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
We did the iron on numbers from RoboPromo. Worked great.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 23-02-2016, 20:46
DonRotolo's Avatar
Back to humble
FRC #0832
White paint is not specifcally illegal, so it should be legal, but of course the standard disclaimer is that I'm not the GDC and my opinions don't count.
You need to be aware that it may take several coats - light coats to prevent runs - to make the white stand out from the fabric. Many teams use fabric paint applied with a small brush instead. In any case, as long as they are white, provide a contrast to the background, and comply with the other rules you should be OK.
Unread 23-02-2016, 21:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have used white paint in the past, but not spray paint. The big problem with paint is that most of the recommended bumper fabrics are nylon or other artificial fiber that do not take most paints well; they tend to flake or peel. If you want to do this, Try painting a scrap of fabric, letting it dry, then striking it against another piece of fabric, polycarbonate, and other surfaces likely to be encountered on the field a few dozen times. You probably will not be happy with the results.
Many t-shirt shops can provide iron-on numbers, or you can order them on-line from AndyMark, RoboPromo, or probably a variety of other vendors. Some teams make their own heat-applied numbers, but I don't know their recipes. Teams (not mine) have also reported having their numbers silk-screened and seemed happy with the results.
