Go to Post Less playing to the camera, more talking about cool FIRST stuff please. - Cuog [more]
Unread 23-02-2016, 18:57
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Smart phone use on robot
I was under the impression that COTS computing devices could run off their own internal batteries. I would be more concerned about a wired LAN connection to an iPhone, it can be done using an Apple branded USB to Ethernet adaptor, a powered USB hub and an Apple Female USB to Lightning adaptor. I'm unsure of the reason the hub is necessary, but I imagine it is to supply input power since ethernet doesn't carry enough on its own. Seems like a lot of work when a USB Webcam plugged into the roboRIO should accomplish the same thing.
Update:
R31 at the very end: "Additionally, batteries integral to and part of a COTS computing device or self-contained camera are also permitted (e.g. laptop batteries, GoPro style camera, etc.), provided they’re only used to power the COTS computing device and any peripheral COTS USB input devices connected to the COTS computing device and they are securely fastened to the ROBOT."
This would indicate that an iPhone on board is not limited by it's battery. You may have to prove that it isn't interfacing with any wireless networks and of course use the method described to connect it to LAN.
2015 GKC Engineering Inspiration
2015 Colorado Winners
