Go to Post The 2006 FRC Manual: Read it. Learn it. Know it. - dlavery [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 23-02-2016, 17:37
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Thoughts On Comments In Team Code
I was busy rewriting my teams code today, just cleaning up some things and adding comments, and I realized that I tend to over comment things (at least in my opinion) when I write code for robotics. Upon realizing this, I decided that in reality, it's good that I over comment my code, as we always have some new programmers each year, and I think it's good for all the comments to be there so that they know what's going on and can hopefully learn how the code works so that they can then go and write it on their own. Here's a sample of the amount of comments I tend to write:
void DriveBase::DriveTank(float left_speed, float right_speed){
	//This method drives each side of the robot using set values
	//The values are not changed in any way
	//Since the right motors are opposite of the left motors, their values are inverted in the command
	//Because of this, when the speeds are output to the SmartDashboard we invert the inverted value
	fl_motor->Set(left_speed); //Sets the front left motor to the left speed
	fr_motor->Set(right_speed); //Sets the front right motor to the right speed
	bl_motor->Set(left_speed); //Sets the back left motor to the left speed
	br_motor->Set(right_speed); //Sets the back right motor to the right speed
	SmartDashboard::PutNumber("Left Speed", left_speed); //Puts the left speed on SmartDashboard
	SmartDashboard::PutNumber("Right Speed", right_speed * -1); //Puts the inverted right speed on SmartDashboard
So here's my question to you, the programmers on Chief Delphi: What's your opinion on commenting robot code? Should there be an insane amount of comments so that new kids understand what's going on, or do you prefer to live by the mantra always repeated to me, "good code should explain itself"?
Let me know what you guys think, I'm very interested in knowing your opinions on the subject.
Isaac
Chief of Programming and Head of Autonomous Control
FRC Team 1410
Unread 23-02-2016, 17:40
Alex Webber Alex Webber is offline
Programming / Web Site / Scouting
FRC #1810 (Jaguar Robotics)
Rookie Year: 2015
Alex Webber is on a distinguished road
Re: Thoughts On Comments In Team Code
Our team doesn't put cmments inside our methods. We Java Doc our code, with easily explainable wording so others can understand what is going on.
During development we typically do, but we transfer to Java Docs sooner or later.
Alex Webber | Co-Programming Lead and Scouting Lead
Jaguar Robotics FRC 1810
2015 | Greater Kansas City Regional 16/54
2016 | Greater Kansas City Imagery Award
2016 | Iowa Regional
Unread 23-02-2016, 17:50
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Originally Posted by Alex Webber View Post
Our team doesn't put code inside our methods.
I'm curious as to how you manage to do that and still have a functional robot
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 23-02-2016, 17:52
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
So I comment my code a lot, but I don't comment the obvious. Like setting the speed to the motors is pretty clear from the code. But I did change the variable names on the code to make it clear it was front_left and not f1. (See you looked to "is that a one or an L"). Same thing with the dashboard. The code is clear, so the "set the dashboard" comments don't add any value. A reminder about the inversion isn't needed since we saw the comment 7 lines before, but it's a little weird, so worth a comment.
And if this is where the drive speed is actually set then I'd do the speed inversion here. That way the entire stack on top is going Foward is positive (+) Reverse is negative (-) and does not need to do the "well the right motors need to be inverted" every place else. That would also get rid of the need to re-invert it back for the display. That would reduce some code complexity.
My 2 cents since you asked, your mileage WILL vary.
	front_left_motor->Set(left_speed); //Set the motor speeds
	front_right_motor->Set(right_speed);
	back_left_motor->Set(left_speed);
	back_right_motor->Set(right_speed);
	SmartDashboard::PutNumber("Right Speed", right_speed * -1); //inverted right speed to make the number positive on the display
And with the inversion done here
	//This method drives each side of the robot. Forward is positive speeds, reverse is negative speeds.
	//Since the right motors are opposite of the left motors, their values are inverted when we set them
	front_right_motor->Set(right_speed * (-1) );
	back_right_motor->Set(right_speed * (-1) );
	SmartDashboard::PutNumber("Right Speed", right_speed);
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 23-02-2016, 17:54
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Our team doesn't put code inside our methods. We Java Doc our code, with easily explainable wording so others can understand what is going on.
Javadoc explains what the method does and anything that's needed for it to work properly. It doesn't explain reasoning behind the logic inside, which is very unhelpful when trying to debug. It doesn't need to be as zealous as OP's example, but you should at least have comments explaining non-obvious code
WPILib
GRIP, RobotBuilder
Unread 23-02-2016, 17:55
Rookie Year: 2015
Oops. Should have been comments. Spell check lol.
Unread 23-02-2016, 17:59
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
I encourage the students to comment the 'why' not the 'what'. When students are writing code the 'what' should be obvious. If not then it should probably be re-written. Commenting 'why' something is done is much more useful to someone reading the code.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 23-02-2016, 19:30
AKA: Isaac
In my experience, it doesn't really change much if you have it in the method or the command, as either way it's just one or two * -1 somewhere in the code. The reason we do it this way is because it just makes things easier when calling it in different commands, but to each their own!
Isaac
FRC Team 1410
Unread 23-02-2016, 19:32
AKA: Isaac
That's a great idea, I'll keep that in mind. I think based off of your advice I'll start having kids comment their code in that way, but I'm going to keep writing my comments as I have been, because some kids like to learn by reading my code, which means I feel like they would benefit from seeing the 'what' along with the 'why'. Thanks for the input!
Isaac
FRC Team 1410
Unread 23-02-2016, 19:34
AKA: Isaac
I'm thinking from a developmental and real world practicing standpoint, this practice would be great, but I'm more wondering about the teaching value of over commenting (if there is any). But I do think from a developmental standpoint I'm going to try to shift my team towards a more 'why' commenting system and less of a 'what', as I said to someone else on this thread. Thank you for your input!
Isaac
FRC Team 1410
Unread 24-02-2016, 10:03
Originally Posted by King Nerd III View Post
Ewww.
Seriously, don't do that. Comments that merely echo the code are distracting at best. They can actually be confusing and counterproductive, as they can give the reader the impression that the author is trying to explain something unobvious about what the code is doing.
Keep putting the "block comments" at the beginning of sections, explaining what the code is for, and explain assumptions and possible side effects, but don't overdo the line-by-line commentary on what the code does. You can better document that kind of information by choosing appropriately detailed and helpful names for functions/methods and variables. For example, instead of the abbreviated fl_motor, make the reader's job easier by calling it front_left_motor. Instead of left_speed, be more explicit with left_speed_desired or left_drive_commanded. That way it is obvious that you're not talking about left_speed_measured or left_intake_commanded.
Unread 24-02-2016, 11:00
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Our coding guidelines at work say this about comments:
Consider using code comments to document code whose operation is not self-evident to the professional developer (e.g. code reviewer). For example, consider commenting:
  • Pre-conditions not evident in code, e.g. thread-safety assumptions
  • Complex algorithms
  • Complex flow of control, e.g. chained asynchronous calls
  • Dependencies on global state
  • Security considerations
Avoid using comments that repeat self-commenting information found in many code structures. For example, do not add vacuous comments such as "Constructors", "Properties", "Using Statements". Avoid commenting:
  • Type declarations (e.g. method signatures)
  • Method overloads
  • Well-understood patterns (e.g. enumerators)
  • Clean code
You would get these code review comments on your method:
  1. Document purpose of method and parameters
  2. Rename fl_motor to front_left_motor, etc.
  3. Input to the method should be in the orientation of the driver, and translated to motor inputs here. This means you'd negate the right value where it's used to set motor speeds
  4. Use "- right_speed" rather than "right_speed - 1"
  5. "Left Speed" should be "Left Drive Speed", etc.
After those changes, the method would look like this:
 * Operate the drive base using tank-style control, where a joystick is
 * assigned to each side of the robot and independently controls its speed.
 * @param left_speed Desired speed of left side of robot
 * @param right_speed Desired speed of right side of robot.
	// Right motors operate in opposite direction of left, so we negate
	// the values here to maintain the correct orientation.
	front_right_motor->Set(-right_speed);
	back_right_motor->Set(-right_speed);
	SmartDashboard::PutNumber("Left Drive Speed", left_speed);
	SmartDashboard::PutNumber("Right Drive Speed", -right_speed);
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 24-02-2016, 11:08
From one who is not a programming person, comments are akin to the "show all your work" direction for math problems. However, when writing consider your audience.
Unread 24-02-2016, 11:29
AKA: Isaac
That's always been my approach to comments. I like to have every part of my thinking written out for me to review later, just like in math class.
Isaac
FRC Team 1410
Unread 24-02-2016, 11:40
Knufire Knufire is offline
I'd echo what Alan said. Using clear variable names and avoiding confusing syntax is better practice than over commenting within code. Definitely have everything documented in Java Docs if you're using Java though.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
