Go to Post The 2006 FRC Manual: Read it. Learn it. Know it. - dlavery [more]
Unread 21-01-2002, 04:41
BinaryBob0001 BinaryBob0001 is offline
BinaryBob0001 is an unknown quantity at this point
How do you control relays
I've been reading about all of the commands on the bs2sx and there seems to be now way to control the relays, is there any way to do this? Thanks.
Unread 21-01-2002, 06:46
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
MOST Pbasic commands are of no use to the FIRST community because you have very little direct access to the outside world.
To turn on or off a relay, all you have to do is change the appropriate bit of the byte RelayA or RelayB prior to outputting the data to the Master CPU at the bottom of your control loop.
It is not that hard once you look closely at the Default Code.
Innovation First has aliased all the bits to things that make sense so for example you simply put
relay1_fwd = 1
to turn relay 1 on in the forward direction
relay1_fwd = 0
turns it back off.
Try it and get back to us with questions if you run into problems
Good luck,
Joe J.
Unread 21-01-2002, 08:42
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
Joe, I am still thrown off by your new pic
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
UNFAIR ADVANTAGE for CDI and new control system archiver 2000 6 23-06-2002 22:13
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
goals: how much control? Pat Sarmiento Rules/Strategy 2 18-01-2002 19:10
