Go to Post If you cannot complete relatively simple tasks, why would anyone assign you something more challenging?? - Chris Fultz [more]
Unread 23-02-2016, 19:57
Miranda_Sharp Miranda_Sharp is offline
FRC #4998
Miranda_Sharp is an unknown quantity at this point
A question about 8in Bumpers...
So, our team is having a debate, because the rules listed in the game manual and the updates don't cover the bumper rule we need for our robot. The entire front of our robot is open, holding a shooting mechanism.
The only "perimeter" is the 3 in total of the end of the chassis. Do each of the 1.5 in count as a whole side that has to be covered, or do we have to have 8 in of bumped extending off of each 1.5 in part of the chassis in the front?
Unread 23-02-2016, 20:03
Re: A question about 8in Bumpers...
The latter, AND you have to have that 8" of bumper backed by the frame perimeter at both ends.
Frame Perimeter is a convex polygon defined by the outermost vertices of the robot, and does not necessarily follow the frame itself. The side of the frame perimeter you show is as long as the robot is wide. 8" from the corners has to be covered.
Looks like you've got a late night and some Thursday at regional work to do.
Unread 23-02-2016, 20:04
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
...hate to be the bearer of bad news, particularly today of all days, but your current configuration appears to be illegal. By
Originally Posted by R19
At least 8 in. of BUMPER must be placed on each side of each outside corner.
and by
Originally Posted by R26
BUMPERS must be supported by the structure/frame of the ROBOT. To be considered supported, a minimum of 1/2 in. at each end of the BUMPER must be backed by the FRAME PERIMETER. Additionally, any gap between the backing material and the frame A. must not be greater than 1/4" deep or B. not more than 8 in. wide.
Edit: Sniped by one EricH.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 23-02-2016, 20:10
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Short answer YES! (and the rules do directly address your situation)
The common confusion is that the rules refer to the "frame perimeter". They should have called it something else like robot perimeter. The frame perimeter is defined as the convex shape formed by rapping a string around your robot at the widest point within the bumper zone (4->12in off ground). Every vertex of the string (which goes straight across your shooter throat) must have bumpers for 8" on both sides of the vertex. The outside corner of your 1x2 frame must have bumpers - fully supported by the frame, extending 8" from the outside corner towards your shooter throat. Very hard to do on bag+tag night.
Unread 23-02-2016, 20:52
FRC #4998
In R19 it also says "If a side is shorter than 8 in., the entire side must be protected by BUMPER (see Figure 4-4)." Because the center is open, are they each a "side"?
It won't be a huge deal, we are prepared to make the a very fun angular front end to make sure it's covered by the 8 in, it's just a little more bumper than we had planned on building.
Unread 23-02-2016, 20:54
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
No. The front is one side, it just has a hole in the middle.
Get a piece of string and wrap it around your robot. Any section of string that is straight represents a side.
Out of curiosity, what is the length from the outer edges of those two outer rails?
Unread 23-02-2016, 21:01
FRC #4998
Our robot is 22 inches wide.
Unread 23-02-2016, 21:03
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
Alright. So, after subtracting two 8 inch sections of bumper on each side, that means you'll have a bumper opening of 6 inches. Unfortunately, I don't think you'll be able to intake a ball through there.
Unread 23-02-2016, 22:03
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It should be named something that actually says what it is - the minimum bounding convex curve in a horizontal plane. If they'd just add convex, calling it the CONVEX FRAME PERIMETER (or even just CONVEX PERIMETER) everywhere the term is used, they'd probably cut the bumper Q&A volume by 75%.
Unread 23-02-2016, 22:13
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Your frame perimeter is widest and longest side in bumper zone...I think you need to create a wider side using an outer frame.
So with 22" depending on how long your bot is as longer as its under 120" you could add bumpers to the side to "outer frame" to get 8" per corner and an intake area for your shooter.
So do the math:
120"> = 44+ LL+ EXTRA WIDTH to create a wider frame side so you can intake the boulder in between
8" -----11" Gap ------8" (Like this on front) so front has to be about 27" wide or more
If it is not create an outer frame -OR- widen your existing bot -OR- narrow your shooter
Our bot for instance is similar its 31" long and 27.5" wide (117" FP) with shooter wheels 11" extended past the actual bumpers attached to our starting config frame perimeter.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 23-02-2016, 22:30
Branden2648's Avatar
Branden2648 Branden2648 is offline
FRC #2648 (Infinite Loop)
Branden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to allBranden2648 is a name known to all
One thing I could recommend if possible is to cut the corners at the opposite side of your robot. This will allow you to add metal to either side of the frame thus making the gap between your 8 in. bumpers widen. I also would say to do some math before you do any cutting if you were to go with this method. Hope this helps! Good luck
Unread 23-02-2016, 22:35
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
You are going to have to make an artificial Frame with some 2x1 or 1x1. Put a 7 inch piece on both sides and maybe a 45 degree angled piece going back to the frame. It will be make bumpers a little more difficult but you gotta do what you gotta do. You may also just extend your frame 8" going to both sides either way its a similar perimeter value.
Unread 23-02-2016, 22:59
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
FIRST needs to make it a point to reiterate the bumper rules in every update next season.
I would hate to see this come Thursday at a regional event from any robot.
No matter how many times its stated, there are always teams that miss this and threads that come up.
Unread 24-02-2016, 00:42
Someone was showing me a video of the Frame Perimeter and how to determine that. That video, or one like it, needs to be played at Kickoff, before the Field Tour videos, and be linked in the Manual.
So many teams at the local scrimmage needed some bumper work... mostly, it was support. A few needed help on the Frame Perimeter (like the team who had one that was really complicated to explain just what was wrong with it--as I recall, it was that their treads were in the Bumper Zone, and defining their Frame Perimeter, while their Bumpers were secured up higher, but not quite fully backed. I suggested that they fully back their bumpers--corner-type bumpers here--and that would prevent their treads from illegally defining their Frame Perimeter. That was a fun explanation...)
Unread 24-02-2016, 01:15
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Just a couple of ideas here to help make the most of the situation:
  1. If your frame perimeter, as defined by <R2>, is smaller than the maximum 120 inches, you could try and make your robot wider, effectively moving the corner further out, and preventing the 8" of bumper from blocking the ball.
  2. Another Thing you could try is to mount the bumpers as high as possible, so that only the top of the ball would have to pass through the gap. the bumper zone is 4"-12" from the ground, and since the bumpers are 5" high, you could have the lowest part of the bumper at 7". with a ball 9.5" in a diameter - it might be able to pass through!
According to this sketch, looks like you need to widen your robot by about 3" in order to intake a boulder.
Another radical notion is to modify it to receive boulder from the embrasure.
Good luck, and feel free to ask for further explanation if needed.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
