Go to Post Thank you NASA (except for Dave, his tormenting hints make us even) - Mike Schroeder [more]
Unread 23-02-2016, 19:39
Espo Espo is offline
AKA: Ben
FRC #5113 (Combustible Lemons)
Rookie Year: 2016
Espo is an unknown quantity at this point
How do I issue a trigger?
We are using an ultrasonic range finder (Maxsonic MB1300), and we need to use the RoboRio to trigger the pulse. The sensor has an input pin that accepts either 0 volts (low) or 5 volts (high). Does the RoboRio have a controllable output that we can drive to low and high?
Unread 23-02-2016, 20:21
Re: How do I issue a trigger?
Use a roboRIO Digital line configured to be an Output (DIO)
Unread 23-02-2016, 23:39
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
DIOs are nominally 3.3V. PWM and relay ports are 5V; for this application, relay ports make more sense.
