LimitSwitches
Hello I am trying to make a motor run forwards only when im holding a button and stop if I release the button OR if the thing the motor is moving hits a limitswitch
I have it going up and down ONLY when the button is held but the moment I try to add limitswitch code it stops working lift is the subsystem - liftUp, liftDown, and liftStop are the commands and in the OI the buttons are in a group all with armLiftDown or Up or Stop Also how do I make the chooser code in Robot.java work. I don't see the autonomous command I set in the Driver Station Here is the code on GitHub: https://github.com/FranklinMarquette/Robot2016 Thanks so much for the help! |
Re: LimitSwitches
Your choice of verb "hits" raises a red flag. Just in case, please read this thread.
What motor controller are you using?? |
The following WPIlib document provides a nice example of setting up an autonomous chooser: http://wpilib.screenstepslive.com/s/...smartdashboard
As far as using your limit switch, I only saw the construction of the DigitalInput objects in your Lift subsystem (usage was commented out). I would suggest the following:
Here are some suggested changes to Lift.java Code:
package org.usfirst.frc.team4623.robot.subsystems;
import edu.wpi.first.wpilibj.Counter;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
public class Lift extends Subsystem {
Victor liftMotor = new Victor(7);
DigitalInput topSwitch, botSwitch;
Counter topCounter, botCounter;
public Lift() {
topSwitch = new DigitalInput(0);
botSwitch = new DigitalInput(1);
topCounter = new Counter(topSwitch);
botCounter = new Counter(botSwitch);
LiveWindow.addActuator("Lift", "Motor", liftMotor);
LiveWindow.addSensor("Lift", "Top Switch", topSwitch);
LiveWindow.addSensor("Lift", "Top Count", topCounter);
LiveWindow.addSensor("Lift", "Bot Switch", botSwitch);
LiveWindow.addSensor("Lift", "Bot Count", botCounter);
* @return Number of times the top limit switch has been hit.
public int getTopCount() {
return topCounter.get();
* @return Number of times the bottom limit switch has been hit.
public int getBotCount() {
return botCounter.get();
public void liftUp() {
double power = 1;
// stop motor if attempt is made to go past the top
if (topSwitch.get()) {
power = 0;
liftMotor.set(power);
public void liftDown() {
double power = -1;
// stop motor if attempt made to go past bottom
if (botSwitch.get()) {
power = 0;
public void liftStop() {
liftMotor.set(0);
protected void initDefaultCommand() {
package org.usfirst.frc.team4623.robot.commands;
import org.usfirst.frc.team4623.robot.Robot;
import edu.wpi.first.wpilibj.command.Command;
public class liftUp extends Command {
// Used to detect the case of going past the limit switch
private int limitCnt;
public liftUp() {
requires(Robot.lift);
protected void initialize() {
limitCnt = Robot.lift.getTopCount();
protected void execute() {
if (limitCnt == Robot.lift.getTopCount()) {
// Have not gone past limit switch, OK to try and move up
// (lift subsystem will stop us if we are on the limit switch)
Robot.lift.liftUp();
} else {
// Somehow we got past the top limit switch, stop motors!
Robot.lift.liftStop();
protected boolean isFinished() {
return false;
protected void end() {
protected void interrupted() {
end();
Also, the counter safety checks will only save you one time using the approach shown. For example, if your lift goes past the top limit switch and you issue the lift up command again, the lift will continue moving up and never stop (expect bad things to happen). |
Re: LimitSwitches
Alternatively, you can do fairly sophisticated software control on your lift such that it knows when it's approaching the limit switches (via encoder/potentiometer) and applies PID control to slow it down. So eventually, it will gently "hit" the limit switch and stop. In fact with this capability, you don't even need the upper limit switch, this is called "soft limit". This is especially useful because while it is generally easy to add a lower limit switch, it is sometimes difficult to add an upper limit switch. For example, if you have an extending arm, it is sometimes impossible to find a place to mount an upper limit switch because it extends into open space. We have a PIDMotor class in our library that implements this capability. There is a method in this class:
public void setPidPower(double power, double minPos, double maxPos, boolean holdTarget) https://github.com/trc492/Frc2016Fir...cPidMotor.java |
