Go to Post FIRST is more than FRC. - gblake [more]
Unread 24-02-2016, 09:07
Re: Encoders direct driven by mini cim? Is it bad?
Originally Posted by aphelps231 View Post
Our main technical mentor said we can't put an encoder on our shooter, driven by mini CIMs, because it would overload the code or something.
Encoder signal detection and processing is handled by the FPGA in the roboRIO. Your code runs in the CPU. So using an encoder will not steal resources from your code.
Being the one who designed and built the shooter, I've been kicking myself in the butt trying to figure out how to get some type of low res encoder on it. So far we've tried a Hall effect sensor and a metal proximity detector, with magnets on the shaft and bolt heads on a hex hub, respectively. Both didn't work.
I wish you had posted here when you were trying to get it to work. Many many teams have successfully used Hall sensors for shooter wheel speed control.
would an encoder reading downwards of 2,000 cps (counts per second, 5,800 RPM @ 20 ticks/rotation = ~2,000 cps) overload the code/RoboRIO?
No. See previous comment about FPGA vs CPU.
I'd like to say no since the RoboRIO operates in the MHz (I think) and that should be plenty but id love it if you would share your experiences.
The FPGA samples the DIO for edges at 40MHz. This is completely separate from the roboRIO's CPU, which has 2 cores each running at 667 MHz. Your code runs in the CPU.
The same mentor suggested we use an algorithm based on battery voltage to decide how much voltage to give the shooter.
This can help, but it's not as effective as using speed feedback.
I really don't like this option, I'd rather run it open loop since battery voltage is constantly fluctuating.
The whole point of using a voltage-based algorithm is to compensate for the fluctuating voltage. But it's not the best way to control speed.
There is a 20 tick encoder on andymark that mounts directly to a mini cim.
What is the part number of that encoder?
Unread 24-02-2016, 10:22
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
we are using a magnetic encoder with the talon srx and java seems to be working well for us. i am not the programmer but may be able to get and post code. pm me if you are interested
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 24-02-2016, 11:40
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
http://www.andymark.com/encoder-p/am-3314.htm
am-3314
team1318.org
2016: Flight Director, Alliance/Match Strategy
2015: Mechanical Lead
2013-2014: Fabrication
2016: 2x district finalists, Quality, DCMP Entrepreneurship Awards
2015: 3x district winners, Innovation in Control, Creativity, Team Spirit awards
2014: Galileo Division finalists, PNW District Championship winners, 1x district winners, District Chairman's, Innovation in Control, Entrpreneurship awards
2013: Entrepreneurship award
Unread 24-02-2016, 13:03
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
We have used both a $5 IR light sensor of ebay pointed at a black and white disk attached to a shooter. Also used an industrial IR light sensor. Both seemed to work.
We have also used a grayhill encoder in the past but you would be operating it slightly above its rated RPM of 5000.
http://www.grayhill.com/assets/1/7/Opt_Encoder_63R.pdf
Unread 24-02-2016, 13:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We had the VP encoders in 'Quadrature' mode hooked up to the Talon SRX's in 'Speed' mode, running at 8k RPM. Was pretty nice to not have to worry about the RIO running the sensing for 2 shooter wheels, the tilt potentiometer and turret absolute encoder - the SRX's do it all individually.
We're switching to the CIMcoder and a CIM-ile setup for non-sensor reasons though.
GitHub
