Go to Post If you have time to complain about how other people are making a difference, it's clear that YOU are not working hard enough to make a difference. - Foster [more]
Unread 24-02-2016, 10:06
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Re: How close...
Do not mention this to the build team, I can already see chartering flights. The fun part is our bagged robot is pristine. It has never had power run to it. Our practice bot is taking the learning curve abuse, but the competition bot won't be run until the time before our first event.
Unread 25-02-2016, 00:39
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: How close...
Is that really that smart, not even testing it once .
Unread 25-02-2016, 01:00
AKA: Rich Lester
Re: How close...
We have run the motors to test the mechanisms, just not everything together. We also have an identical bot, so it isn't as bad as I made it sound. The only things we should need to do in our 6 hours is power it up, deploy the final code and we should be good to go. Hopefully the only difference between our competition bot and practice bot will be that the practice bot has been flipped over a few times during practice.
