Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 23-02-2016, 14:40
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: Air Game 2016 - Do you have it?
Originally Posted by Sperkowsky View Post
Unless there are FMS issues.
True. But that should never be considered a valid strategic option.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 23-02-2016, 14:45
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
Originally Posted by glennword View Post
I think you saw it in the old television show called Dukes of Hazard. Here's a pic
Plus one sir! Dukes of Stronghold.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 23-02-2016, 15:24
Dezion's Avatar
Dezion Dezion is offline
Coach | Strategy Co-Lead | Raawr!
FRC #4935 (T-Rex)
Rookie Year: 2015
Dezion is an unknown quantity at this point
You do not understand how much you scared our team with that. I believe half the team was about to have a heart attack from our dreams being crushed. But, thankfully it was not.
Unread 24-02-2016, 11:21
dv/dt dv/dt is offline
FRC #2990 (Hotwire Robotics)
dv/dt is on a distinguished road
Originally Posted by OccamzRazor View Post
He means the wheels and the position of the robot, same as ours. Did you guys also use the harbor freight tires and slice the rims to make the tires seal to the AM hubs?
We ended up keeping the HF rims, milling out the bearing hub and having some replacement hubs waterjet cut that uses the bolt pattern of the HF rims and a 1/2" hex hole. One hub on each side of the rims. We're really happy with these tires/hubs, they fit the sweet spot for our drivetrain between the AM tires and some 10" tires we tried.
Unread 24-02-2016, 11:41
traxxasracr1's Avatar
traxxasracr1 traxxasracr1 is offline
AKA: Blake Hobbs
FRC #3255 (SuperNURDs)
Team Role: CAD
traxxasracr1 will become famous soon enough
http://www.chiefdelphi.com/media/photos/42870?
We hit the moat at full speed in high gear, just for fun.
Unread 24-02-2016, 12:34
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
https://twitter.com/FRC3005/status/699014351399718912
Our preferred method is hitting the defenses fast and going dukes of hazard on them, but proper tire inflation keeps us from catching quite as impressive of air.
2013 - 2017 - Mentor - Robochargers 3005
2014 - 2017 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 24-02-2016, 13:33
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
As far as I know (being the programming mentor, and not mechanical :-P ), we used the same hubs that they came with (yes, the same Harbor Freight wheels), but we had to make custom covers to size up to the hex shaft (if that makes sense).
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 24-02-2016, 13:35
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
http://i.giphy.com/JgYZvEAznnlm0.gif
A GIF of the robot jumping over the defense platform and low bar, sans actual bar.
http://i.giphy.com/xT0BKhisZ6zncmfhgQ.gif
Also, not necessarily a jump but probably the most impressive accidental trick we have done. That's what happens when your drivers ride BMX.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 24-02-2016, 13:37
jojoguy10's Avatar
AKA: Joe Kelly
This! This is amazing! Haha!
Unread 24-02-2016, 16:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I really want to take ours to the skate park. It's so fun to jump this thing off stuff.
Unread 24-02-2016, 18:26
gegozi gegozi is offline
gegozi is an unknown quantity at this point
Originally Posted by Zac Schofield View Post
A week ago when we were testing our backup robot, (So that we wouldn't break our main one in testing) our Driver drove over the rock wall, and the robot flipped forward and landed upside down... Now, as some of you may know, that's where a lot of the important electrical things are... So our driver cracked our RoboRio, and it's completely destroyed.
We're never going to let him live that down
I hope you have a new rio, otherwise good luck, especially if you are competing early.
I wish you good luck either way, but you will especially need it if your roborio does not work...
Unread 01-03-2016, 09:48
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
Nice Stoppie! Love it!
Unread 01-03-2016, 09:51
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
We would have had a whole shop working to fix your bot too! Thankfully no robots were injured in the making of our fail.
Unread 01-03-2016, 15:59
frcguy's Avatar
Unregistered Unuser
Yeah! I didn't think anyone would understand it if the caption was stoppie nose-manual.
