Go to Post I think that if you're using semantics to pass inspection you're trying hard to be lazy (Trust me I'm really good at doing it). - Thayer McCollum [more]
Unread 23-02-2016, 21:00
MBimrose16's Avatar
MBimrose16 MBimrose16 is offline
AKA: Miles Bimrose
FRC #3865 (Riley WildBots)
MBimrose16 will become famous soon enough
Exclamation Help: Electronics out of Bag and Tag?
My team was practicing some autonomous code and our robot accelerated into a desk shattering the plexiglass that our electronics board was on. We disconnected all the components which were intact, but need to be remounted to a solid board. I understand that the weight of the electronics will be counted against the 30 pound limit that we can bring to competition, but are there any rules that prevent us from leaving all of the electronics out of bag and tag? The attached image is everything we had to take off. Thank you for your help ahead of time.
Unread 23-02-2016, 21:11
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Help: Electronics out of Bag and Tag?
You should be OK!
R18
Unread 23-02-2016, 21:22
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Originally Posted by Conor Ryan View Post
You should be OK!
R18
Yep, you guys are fine here! Good luck!
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 23-02-2016, 21:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The most important thing is that if you re-assemble a control board and bring it to your first event, the entire weight of that board including the COTS components, is part of your 30 pound withholding allowance. If you bring in a COTS sized piece of plexi, spools of wire, crimp connectors, and the COTS roboRIO, motor controllers, etc., it's all COTS stuff and does not count against your 30 pound withholding allowance. You may find it most expedient to go somewhere in between, especially if you are planning to add or work on a manipulator or two between now and your first event. Also note that the COTS rules are slightly more restrictive for withholding than for beginning of season.
Unread 24-02-2016, 10:23
Make sure you add this to your "lessons learned" file: Never use acrylic/plexiglass on a robot. Especially in a game like this year, where there's going to be a lot of bumping and banging and bouncing.
Unread 24-02-2016, 10:31
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
What Geetwo said.
I would take the solid board, prepare mounting points (including what mounts to the board), and run all the wires where then need to go. That shouldn't weigh too much against your Withholding Allowance.
Separately bring in COTS electronics. In the Pit, mount the electronics, and connect them.
Unread 24-02-2016, 11:06
M,
GDC ruled (via Q&A) that the RoboRio does not change COTS status when you remove it from a robot even if you loaded software on it. Other components may transfer to FABRICATED items when you mount/wire them. If you bring each item to your next competition in the COTS state and reassemble it, it will not count towards your withholding allowance. Wires cut and/or terminated (except on certain motor and controllers) are FABRICATED and must count towards your withholding if you bring them to a competition outside of the bag.
Please pick something other than Plexiglass. You now know it shatters and is not suitable for use on FRC robots for that reason. Under R9, damage to other robots, leaving bits of plastic shards on the field fits into this description.
Unread 24-02-2016, 12:07
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Oh man thats rough. We got rid of all the plexi in our shop for this reason and just have a large amount of lexan on hand. For our electrical board we are using 1/4" perforated polycarb which has held up very nicely and is very easy to mount to.
