Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 24-02-2016, 13:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
pic: FRC 1726 Robot 2016 Stronghold
Unread 24-02-2016, 13:58
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
Re: pic: FRC 1726 Robot 2016 Stronghold
Is this one of those D bots?
Unread 24-02-2016, 14:29
MrForbes's Avatar
AKA: Jim
I don't know what you mean by D bot, if you mean will it play defense? then no, it is a scoring robot. Ball intake under the bumper, shoots low and high goals, crosses all the non-moving defenses on it's own.
Unread 24-02-2016, 14:37
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Impressive ! Any pictures from the underside of the robot.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 24-02-2016, 14:39
MrForbes's Avatar
AKA: Jim
Unfortunately, I'm not bright enough to remember to take pictures of it when it's upside down. Or even of the ball intake, when it's sitting upright.
Unread 24-02-2016, 20:51
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
The intake does look intriguing. Is that a oneway gate for the ball intake? Send us pictures when you can.
Good luck in New York.
Unread 25-02-2016, 14:17
MrForbes's Avatar
AKA: Jim
The ball just goes under the bumper, and there are some various chunks of wood to direct it to the center, where the intake roller is. Then when it contacts the roller, it goes up the track until the sensor detects it, and turns off the roller. When it's time to shoot, the shooter roller spins up, then the intake roller moves the ball further along the track. When it hits the spinning shooter roller, it's gone.
Two moving parts in our ball mechanism. Not bad for having the ability to collect balls, and make high and low goals.
edit: I found a picture, this is sort of old, we added a couple more chunks of wood in there since. And added a belly pan.
Unread 25-02-2016, 14:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The ball just goes under the bumper...
We dubbed this idea "The Pac Man Maneuver". It will be funny to see it in action.
GitHub
