| View Poll Results: How Much Does Your Robot Weigh? (Not including bumpers or battery, in pounds) | |||
| Less than 60 (???) |
12 | 3.83% |
| 61-70 |
9 | 2.88% |
| 71-80 |
16 | 5.11% |
| 81-90 |
47 | 15.02% |
| 91-100 |
88 | 28.12% |
| 101-110 |
63 | 20.13% |
| 111-120 |
62 | 19.81% |
| Over 120 (Good Luck) |
16 | 5.11% |
| Voters: 313. You may not vote on this poll | |||
Re: How Much Does Your Robot Weigh?
Please fill out the poll, just put it up.
Ounces overweight. Going to replace some steel bolts with aluminum in the wheels we got from Amazon, so that'll solve it. Easy.
Is it just me or 254 troll every poll? they said they were going to do less than 10 points in another poll, in this poll 3 team members voted for over weight.
waiting for release video. |
I'm no expert but if you have to take off only a few ounces I would recommend a hole saw and a drill. Since you've already bought the bolts you should defiantly use them but you should put them in the places that have the least stress, wheels are not the best spot.
Probably. |
![]() There's always 4-5 lbs of dead weight on a robot. The hard part is finding it. Last edited by Harman341 : 24-02-2016 at 23:09. |
#7
Before the season started, I budgeted out 98 pounds for our robot (with 22 pounds margin). We weighed in around 87 pounds just before bag...That's without our climber though. It turns out, our shooter was <6 lb even with a flywheel (13 lb budgeted). Drivebase ended up being around 40 pounds with 30 pounds budgeted (didn't expect 8" pneumatic wheels before the season).
#8
A bit shy of 100 pounds estimated (We weighed the main chassis but we are still waiting on pneumatic cylinders from Bimba, so our launcher and pickup will be in the withholding bag). We also have about 7# of steel ballast we can bolt on in about two minutes (holes pre-drilled in both ballast and robot). We sweated frame perimeter (119") and fitting under the low bar more than weight this year.
#9
117.25 lbs. We had the design for a scaler, but not the weight for one.
#10
#11
Thanks to everyone who answered!
#12
We were around 75 pounds. However we are adding a climber which will and another 30 or so. Still can not complain with 105 pounds...
#13
We're pretty close. I think our practice bot is a tad bit heavy, but the competition bot got weight reduction applied prior to bag and should be just...about...there...
#14
Anyone new?
#15
1768's was about 110 without one of the assemblies on, it is still being made right now and will be installed at the competition.
