Go to Post Yeah, that's a hardware problem. Definitely something to blame the electricals for. Programmers just work there. - EricH [more]
Unread 24-02-2016, 12:28
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Have you tried parking on the Batter?
Originally Posted by Ty Tremblay View Post
This is all dependent on gear ratio, wheel size, friction, etc.
^This.
Our robot was at the official Week Zero event and didn't need one to stay on the batter however that wasn't the case for every robot.
If you really want to end the match parked on the Batter, start planning something to hold you there now if you don't have the ability to test your robot on a lexan incline between now and your event.
1058 PVC Pirates 2016 - xxxx
Unread 24-02-2016, 12:42
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Speed controller setting is also important. I'll be checking with every team I encounter that their speed controllers are set to brake mode.
Unread 24-02-2016, 12:45
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Originally Posted by Sperkowsky View Post
It depends a lot on the wheels and gear ratio. With stuff like pneumatic wheels going over the lip pretty much no matter what. The best way to do it is drive on the batter and then rotate or try to drive up at an angle.
I guess this might be an advantage of the plain old Kit Bot drive train as we don't have an issue with that. 8" pneumatic wheels, no other modifications to the provided kit and ours doesn't move when power is cut on the incline of the batter. Maybe I need to find out if the kids actually greased the gearboxes We are also royally underweight, so that is probably helping as well.
Nate
Unread 24-02-2016, 12:53
Joining the 900 Meme Team
FRC #0079
Fair heads up, CAN bus teams can dynamically switch that really easily. It's actually pretty nice.
Unread 24-02-2016, 13:05
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
If you have a heavy end of your robot, park that against the lip. Our robot is pretty heavy on the back when the shooter is up, and stays parked. Low gear and brake mode on the talons helps so if you roll into the lip it is slow.
2016 Central Illinois Winner. Curie Division finalist
Unread 24-02-2016, 13:44
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
daliberator will become famous soon enoughdaliberator will become famous soon enough
Yea we had plenty of teams play defense on us. A good defender can definitely shut us down a bit but, I think they are going to focus on the high goal shooters for the most part. We also have had a lot of driver practice with a week 0, and 5 practice events with other teams.
Were you scoring 8 boulders at Suffield in 5-minute matches, or somewhere else with regulation time? Either way, that's pretty cool.
4536 Team Captain
www.minutebots.org
Unread 24-02-2016, 14:38
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Driver
whitetail is an unknown quantity at this point
We have two fingers that go down and stop us at the end of the match from rolling off the batter.
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590 and 2607)
2016 MAR Hatboro-Horsham District event Winner(Thanks 2607 and 1218)
Unread 24-02-2016, 14:50
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Well both. I think our max at Suffield was 11 with a capture. During a normal match we can do 8. While crossing the B and D defenses. Although we can also do the Cheval DE Frise and Drawbridge solo we can not do it while scoring 8 boulders
Unread 24-02-2016, 18:22
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
"A ROBOT has CHALLENGED the TOWER if, at the conclusion of the MATCH, the ROBOT is fully supported by the TOWER, but hasn’t met the criteria for SCALING the TOWER."
To make sure i understand this correctly, this means that the robot cannot touch the courtyard carpet, it has to be positioned fully on the batter ?
Unread 24-02-2016, 18:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's the plan....
Unread 24-02-2016, 18:35
Chris is me's Avatar
AKA: Pinecone
There were 6 balls on the midfield at Suffield, three at the human player station, and three in all of the robots in your alliance. In order to score 11 balls in a match, you would need to have obtained every ball your alliance could have possibly controlled except for one. Since balls weren't returned to human players, this is a bit suspect. I had to leave Suffield early since 228 had some problems to fix, so I didn't watch all your matches, but this is a tall order even in a 5 minute match. Did they start returning balls by the end of the day or something?
Unread 24-02-2016, 19:21
Sperkowsky's Avatar
They got a shipment of boulders half way through the day.
Unread 24-02-2016, 19:41
I'm going to call a "video or it didn't happen" on this. Please prove me wrong.
Unread 24-02-2016, 19:48
Sperkowsky's Avatar
I'll get a video in 2 weeks.
