Go to Post and if you don't know what i'm doing, that makes two of us. - RogerR [more]
Unread 24-02-2016, 18:20
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
pic: FRC 4329 Presents Trogdor
Unread 24-02-2016, 18:21
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: pic: FRC 4329 Presents Trogdor
What's the brake caliper for ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 24-02-2016, 18:30
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Probably used to hold their intake a different angles. Strait up to be inside perimeter at start of game, let it angle down so can go under portcullis and push down on the teeter totters
Unread 24-02-2016, 18:31
Our original intake pivot used a versaplanetary gearbox to rotate. The idea was that the disc brake would help secure the Intake and hold at a desired position without the need for elastic or stalling the motor. We killed a couple of gearboxes on various defenses and decided to find a way to use pneumatics instead.
We are now looking at 3 position cylinders or to still use the disc brake to halt the motion of the cylinder depending on which position we want via an encoder. The plan is to have a retracted position, intake position and portcullis / chivel de frise position.
All of this happened in the last 4 days so we just left it on for now
Here's a link to a few more images -
http://imgur.com/a/4Zrct
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 24-02-2016, 18:52
bstew's Avatar
bstew bstew is offline
FRC #3928 (Team Neutrino)
Team Role: CAD
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
Looks really nice!
Are you planning to go under the portcullis? The intake looks like it is designed to, but the RoboRIO suggests otherwise.
Unread 24-02-2016, 19:00
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I dig the yellow chords. Are those the ones you connect with the inserts or did you melt them together?
Unread 24-02-2016, 19:04
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Very nice, looks sharp! What are your collector rollers made of? The clear plastic is pretty cool to see through, especially spotting the center bearing in the front roller. I also like how the centering belts are slaved off of the intake belts.
Also, what motor/gear combo did you have on collector lift that was giving you issues?
We actually have a very similar collector (and hope to add a similar shooter later with carry-in allowance, but prioritized climbing over shooting). Our collector uses 3 separate motors though, centering, intake, and rotate up/down. Our rotate is powered by a bag CIM geared 500:1, no brake mechanism (100:1 VersaPlanetary, then VP spur gears 14:70) So far no major issues, and only one smoked motor - from stalling against a hard-stop before limits and closed-loop control were added.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 24-02-2016, 19:33
Originally Posted by bstew View Post
Looks really nice!
Yes we are - we need to still build the superstructure that will keep the portcullis gate above that height. We're also going to add some protection for that top layer of the controls.
Yep they are hollow and we're using the metal insert barbs. Only a few failures so far as we learn how to link them together better.
Originally Posted by Jeffrafa
Very nice, looks sharp! What are your collector rollers made of? Also, what motor/gear combo did you have on collector lift that was giving you issues?
They are made from 1.25 OD polycarbonate, 1/16" thickness. Interfaces perfectly with 1.1.25" bearings.
We tried a MiniCIM into a 1:100 versaplanetary that was built using various stages (2 and 3). The issue wasn't really the gearbox's power, it was the way we were face mounting it using one of the versa gussets. It's generally not a great idea to have your gearbox taking lots of shock loads as you ramp the intake into the various defenses that we're planning on using it on. We want things to be extremely robust for this game so we made a decision to use pneumatics on the pivot and haven't looked back.
Unread 24-02-2016, 19:46
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Trogdor! What a great name for a robot! Why didn't I think of that? Interesting design, too! What size are those drive wheels?
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 24-02-2016, 19:59
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
Take two cylinders of the same stroke that equal the stroke you currently have and mount them opposite each other, you now have a 3 position cylinder. If they are two diffrent strokes that equal the orginal stroke you have 4 positions. We switched our motor driven intake/shooter to a system like this and its is magic.
PM me if you want more info/pictures
All thanks go to Brian from 2791 for introducing this to me
Unread 24-02-2016, 20:57
Weinberger's Avatar
Weinberger Weinberger is offline
FRC #1683 (Techno Titans)
Weinberger is an unknown quantity at this point
Trogdor! The Burninator! Looks like you'll be ready to fight back against that 10th Defense.
Unread 24-02-2016, 21:00
Thanks! I had to educate most of our students because they had no idea who Trogdor the Burninator was. I feel old.
We're using the black versions of the 200 x 50 mm tires from this website: http://www.mfgsupply.com/8-10428.html They're the same as the gray Andymark ones.
Thanks for the tip! I'll shoot you a message for more info.
Unread 24-02-2016, 21:49
Team Role: Student
Rookie Year: 2016
Fire game confirmed! Don't forget to kick the player station wall if something doesn't go the way you wanted it to.
P.S. The think about kicking the player station wall was a joke. Don't actually do that. Especially if you're at the middle station.
Unread 24-02-2016, 23:41
Really really digging the disk brake, I never got to see that update on facebook!
Turned out awesome Ryan! How often are you guys expecting to run practice sessions with the second bot?
Unread 25-02-2016, 10:40
We'll spend this Saturday getting the practice robot matching the bagged competition robot. It shouldn't take much since we can put the competition intake & shooter on our practice robot since it all fit under 30 lbs for withholding -
Once we have that completed, we should have 2 weeks of drive team practice & autonomous development for St. Louis.
