Go to Post John is the king of vague, but then again he looks much better at a distance than he does up close :D - Rich Kressly [more]
Unread 02-24-2016, 07:42 PM
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Mentor seeking advice.
Originally Posted by ROUS View Post
Hi, so I'm a former FIRST team member (animation, oddly enough) and I've just begun mentoring a team for the 2016 build season.
My primary skill set rests in fabrication and mechanical, however I have past experience with electronics and programming. I'd like to acquire a working knowledge of the communication/control system so that I might be of more use to the team. I haven't been on a FIRST robotics team since I was in high school (think 2001) so I'm a little out-of-the-loop, technology-wise.
Where does one start learning about Talons and LabView and C++, and making them all work together? Is there an inexpensive starter kit I can buy to tinker with at home, and learn how to write code to control a simple robot?
You are in Philly?
Any chance you are a NextFAB member like me?
I might be willing to work out something to give a class with my robot and control systems.
Unread 02-24-2016, 07:45 PM
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
GameSense did a show on the current control system last year as part of our Behind The Lines series.
Unread 02-24-2016, 08:03 PM
ROUS ROUS is offline
Team 321 Mentor / Team 103 Alum
FRC #0321 (RoboLancers)
ROUS is an unknown quantity at this point
Originally Posted by techhelpbb View Post
You are in Philly?
I was a nextfab member, but I let my membership lapse when I moved away from Washington Ave. and I stopped going very often. I took classes in ShopBot, laser cutting and 3D printing, but never got anywhere near any robots.
Unread 02-24-2016, 09:03 PM
techhelpbb's Avatar
That would be because I was not bringing an FRC robot there at the time
I live in Northern, NJ and as a NextFAB member I could come there with said stuff.
Hence it works for me to go 2.5 hours south.
It would simply be neutral space and since you had to pass shop safety to get to the ShopBot at least I know you know how to not dismember yourself
Unread 02-25-2016, 02:54 PM
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
The wpilib Eclipse plugin includes lots of example programs. Just go New->Project and select wpilib Java Example or C++ Example. You'll get a window with a list of examples. Select one and start poking around.
Would have saved me a lot of time and Googling had I known about this during last year's build season!
Unread 02-25-2016, 03:00 PM
couvillion couvillion is offline
FRC #1818
couvillion is an unknown quantity at this point
Has anyone played with this SparkFun Inventor's Kit for LabVIEW with an eye towards learning LabVIEW for FRC?
Unread 02-25-2016, 04:25 PM
JStein JStein is offline
AKA: Justin Steinlage
FRC #1756 (Argos)
JStein is an unknown quantity at this point
A couple of Team Argos mentors (me included) worked through the off season to build a training platform for the FRC community. We've used the Argobot throughout our build season to get our software/controls students up to speed quickly, with many students able to go from never having run LabVIEW to getting the Argobot running in 60 minutes. They've learned about using touch, proximity, ultrasonic and inertial sensors over the past 6 weeks, most of which are being used on our robot. It's based on the Digilent WF32 board running LINX, and has a whole host of tutorials on YouTube to get started.
Unread 02-25-2016, 09:48 PM
This is very cool. The Argos seems like the perfect place to start, however the price is a wee bit steep for an impulse-buy. I guess it's an investment in my knowledge and ability to help the team. Is there no cheaper (think $100-150) way to get into this?
