Go to Post They were designed that way so they would be compatible with the water-based ga.... oops, sorry, we aren't supposed to say anything about that. Never mind. - dlavery [more]
Unread 24-02-2016, 20:38
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Stop a cam at top dead center TDC
Well bag and tag is over. We have a cam on the output of a Toughbox mini with a mini cim powering the box. We have an encoder sensing the rotation. We where unable to create, test, and troubleshoot code to have the cam retun to TDC after the button is released. We are using the command bassed template. The cam may spin any number of rotations in either direction. When we are done we want to return to the top either continueing in the same direction or reverse. What might be a good way to do this? Should we check the current count by modulus 360 and continue to the next 360 increment. Any input. Its going to be tough to test now without a rio
Unread 24-02-2016, 20:47
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Stop a cam at top dead center TDC
Can you post your code?
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 24-02-2016, 21:39
DonRotolo's Avatar
Back to humble
FRC #0832
I might consider a limit switch to sense TDC; your encoder is also self-calibrating. The switch doesn't need to be at TDC, just be able to close (briefly) when the cam is in the right position.
Unread 24-02-2016, 21:56
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
we used a cam in our shooter this year. we used a limit switch to stop it when it's fully loaded, and when we shoot its loads automatically and stops when it hits the limit switch again. You could also use an absolute magnetic encoder to sense where you are, or use the modulus, like you said
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 24-02-2016, 22:00
Rookie Year: 2015
We have no code yet and testing will be tough without the rio. A limit switch does seem to be the bestangle. We will have to try and fit it at the show. We only had a day of code tests this year. I come from an industrial background with servos and encoders for positioning. When building this system I suggested an encoder. Should have designed for Limit switch
Unread 24-02-2016, 22:10
I hope it's just actuating the limit switch, and not hitting it
Unread 24-02-2016, 22:23
Drive Coach
AKA: Antoine L.
Yeah that's what happens when English is not your first language
