Go to Post I worship whoever cleans the robotics room. - John Gutmann [more]
View Poll Results: How Much Does Your Robot Weigh? (Not including bumpers or battery, in pounds)
Less than 60 (???) 12 3.83%
61-70 9 2.88%
71-80 16 5.11%
81-90 47 15.02%
91-100 88 28.12%
101-110 63 20.13%
111-120 62 19.81%
Over 120 (Good Luck) 16 5.11%
Voters: 313. You may not vote on this poll
Unread 24-02-2016, 22:49
BrendanM's Avatar
BrendanM BrendanM is offline
Lead Mechanic / Electrician, CAD
FRC #0250 (Dynamos)
BrendanM is an unknown quantity at this point
Re: How Much Does Your Robot Weigh?
Originally Posted by JesseK View Post
Ounces overweight. Going to replace some steel bolts with aluminum in the wheels we got from Amazon, so that'll solve it. Easy.
I'm no expert but if you have to take off only a few ounces I would recommend a hole saw and a drill. Since you've already bought the bolts you should defiantly use them but you should put them in the places that have the least stress, wheels are not the best spot.
