Team 706: Cyberhawks 2016 Robot: Knighthawk
The Cyberhawks, Team 706 are proud to present our 2016 FRC Stronghold robot:
KNIGHTHAWK http://imgur.com/a/RrILs ![]() ![]() ![]() Quick Specs: - 27"x32"x12.5" - ~95lbs - 4 CIM, 6 wheel tank drive w/ super shifters on 9.4" "Balloon" tires geared for 15/8.5 fps - Low bar capable - Traverses A,B, and D defenses and can drive backwards through/hold open C defenses - Round Belt intake (9:1 BAG) w/ dual purpose as Portcullis lifter/Cheval de Frise leveler (arm driven by a 150:1 MINICIM) - Shoots high goal from Batter - Shooter arm (800:1 775Pro) w/ pneumatic punch shooter and dual purpose as hook positioner for hang - PTO from middle drive wheel to ratcheting winch drum to lift robot for hang with 4 CIMs worth of power *the hook's cables are not installed yet in these images. We will be competing at the Milwaukee and Buckeye regionals. A full release video will be out in the next couple of weeks. See you at the competition! |
Re: Team 706: Cyberhawks 2016 Robot: Knighthawk
What type of tires are on your drive system? I thought your tires were boulders for a few seconds when I saw the third picture.
Very sweet robot guys! Good luck at Buckeye and Milwaukee! Wish we would of done Buckeye this year to see you guys!
Great looking robot!
Holy cow. Can't wait to see it on the field! |
Thanks guys!
The wheels called "balloon" or "beach tires" and people often use them on off-road beach wheelchair or carts. They are inflated to a pressure of only 2.5psi, so the robot handles the defenses really smoothly. They came with bushings which we broached to 1/2" hex. We are using the24cm versions: http://wheeleez.com/beach-wheels-polyurethane.php |
Here is an image with the shooter's arm down:
#7
It was sweet to see this in person in Sussex last weekend. Good luck to you guys, see you in Milwaukee!
#8
Sick looking machine yet again. It is insane you guys have yet to win a regional. Hopefully this is the year the Finalist streak ends and you get those blue banners! |
#9
Nice looking machine, again. It seems whichever spy was feeding our teams similar designs the past two years has failed this year.
Look forward to seeing you guys in Wisconsin. |
#10
From causally watching the webcast on Sunday, it looks like an accurate high goal shooter. |
#11
Looks really clean guys.
Any chance you can shed some light on the size and type of cylinders and solenoids being used in this design? Thanks. |
#12
http://www.andymark.com/Pneumatic-p/am-3324.htm Each solenoid valve has a 60psi tank attached right to the input it to keep maximum air flow. On the output sides each solenoid is plumbed with two tubes (a brass tee to two 1/4" tubes) to the cylinders on both the retract and extend. The 2 shooter cylinders are 12" stroke, 3/4" bore, and cushioned on both ends.* Both the cylinders pre-pressurized and are held back with a 3/4" bore, 1" stroke pneumatic trigger cylinder. All other solenoid valves are the smaller Festo valves. *We had a similar design in 2014 and had a problem cracking the tees on the cylinder ends because of the shock loads of the shooter at the ends of its stroke, hence the cushions. Hope this helps! |
#13
Yea, we are definitely hoping to be able to break through this year. It has become a bit of a joke on our team about being a great "2nd place" team. We competed against 2481 in the finals the year they broke through. They build some pretty awesome machines. Thanks! We did a lot of testing with the prototype shooter and some idea pulling from our 2014 robot which had a similar pneumatic punch. |
#14
We had some issues: http://www.chiefdelphi.com/forums/sh...&highlight=706 But will all of our success even with our issues we have done pretty well. |
#15
Is there any videos of this in action? Beautiful bot by the way
