Go to Post Active control of game pieces throughout all stages of your robot's interactions with it is critical. Never let gravity/inertia control the game piece. If you want a game piece to go somewhere, you MAKE it go there. - Jeremy Germita [more]
Unread 25-02-2016, 00:39
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: How close...
Originally Posted by hardcopi View Post
Do not mention this to the build team, I can already see chartering flights. The fun part is our bagged robot is pristine. It has never had power run to it. Our practice bot is taking the learning curve abuse, but the competition bot won't be run until the time before our first event.
Is that really that smart, not even testing it once .
Unread 25-02-2016, 01:00
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Re: How close...
We have run the motors to test the mechanisms, just not everything together. We also have an identical bot, so it isn't as bad as I made it sound. The only things we should need to do in our 6 hours is power it up, deploy the final code and we should be good to go. Hopefully the only difference between our competition bot and practice bot will be that the practice bot has been flipped over a few times during practice.
Unread 25-02-2016, 02:20
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: How close...
Originally Posted by The Doctor View Post
That's why you live in japan so you have 10(?) extra hours..
/s
We got done around 11:48 this time.
Japan is on the other side of the international date line, making it 14 hours ahead.
In other words, it's Thursday here. Why haven't Palmetto practice matches started yet.
Unread 25-02-2016, 06:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: How close...
1207. Fortunately, that was a few minutes after noon, not midnight. We were aiming to beat the weather rather than the clock this year; we had tornadoes just a few miles down the road in several directions.
Unread 25-02-2016, 09:01
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Re: How close...
I'm not sure when we started bagging but after that bag was tagged, it was exactly 11:59. We basically drove the robot until right before needing to bag it.
Unread 25-02-2016, 13:37
xjschwen xjschwen is offline
FRC #3668
xjschwen is an unknown quantity at this point
Re: How close...
9:00 PM... We did not push it...
Unread 25-02-2016, 13:58
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: How close...
We were working with a nearby team - #949, Bellevue High School.
We bagged at 9:48 PM and they bagged theirs at 9:49 PM.
Unread 25-02-2016, 14:13
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How close...
I don't know, I left early. The robot was working when I left.
Unread 25-02-2016, 15:18
Brian C's Avatar
Brian C Brian C is online now
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: How close...
This should be added to the thread "quotes said during the build season".
It's a line that fits our team just about anytime during the 4th to 6th week of the build season. Usually a reply to the question "what the heck happened?"
2017 Season; Game Announcer at
SBPLI Long Island Regional
