Go to Post this thread made crave bacon so badly that I am now, as I write this, cooking 2 pounds of it. :o - gvarndell [more]
  #31   Spotlight this post!
Unread 25-02-2016, 11:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Al's 2016 Inspection Thread
My understanding is that the "shorter than 8 inch" rule was placed there to explicitly allow sides shorter than 8 inches (and require that they have bumpers). Without this rule, you couldn't have a (for example) four-inch long side because you could not then put 8 inches of bumper extending from each corner without violating other bumper rules limiting extension of hard and soft parts away from the frame perimeter.
  #32   Spotlight this post!
Unread 25-02-2016, 11:57
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Originally Posted by gpetilli View Post
I disagree the minimum side is 16". I propose that a side that is 8" long, completely protected by bumpers has bumpers 8" from each vertex. The minimum side is essentially 8" not 16". Of course the other side of each of those vertexes also need at minimum 8" of bumper.
The completely covered wording was intended to address the "infinite vertexes" case of a circular robot.
It also covers cases where a robots side is less than 8". I've seen teams cut the corners off their ROBOT to help with frame perimeter issues, leaving a side of 1-3". Fully cover that side, plus 8" on the other sides of each of those corners along the longer sides.
2016: Lake Superior WFFA
  #33   Spotlight this post!
Unread 25-02-2016, 12:20
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
I think that the manual needs to have more bumper pictures after R19. Particularly, it needs one showing a side that is less than 8" that has legal bumpers on it. The bottom right corner of robot C should also be split into a couple of pictures, because there is too much happening there right now to clearly see why specific aspects of that configuration are illegal.
Also, another term should be added to the glossary to differentiate what we conventionally think of as a "side" and a side as determined by the frame perimeter. Perhaps FRAME PERIMETER SIDE would suffice.
  #34   Spotlight this post!
Unread 25-02-2016, 13:44
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Maybe differentiate a side from a segment of a side (for sides with gaps)? Maybe outlaw circular bumpers and require "organic" convex perimeter shapes to be made from >8" segments of bumper with supporting 8" rigid frame? I vote for CONVEX PERIMETER to replace FRAME perimeter (which I believe is a major source of the confusion) Given the large number of redundant Q&A, the intent is clearly not easily conveyed.
  #35   Spotlight this post!
Unread 25-02-2016, 13:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I think most of the bumper confusion is teams trying to fit the rules to their robot rather than the robot to the rules. The 2011 rules had the effect that the minimum frame segment was 6" since the minimum bumper length was 6 inches. IE no round robots. Gaps in bumpers were not allowed in 2011. I think the current rule phrasing came about from changes that allows bumper gaps & round robots. Better phrasing might be segments less than 16" require full bumpers and segment greater than 16" require 8" from each vertex since that is the effect of the current rule.
  #36   Spotlight this post!
Unread 25-02-2016, 14:17
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I liked the 2013 version of this rule (as clarified in a team update) that essentially said the required 8 inches wraps around the next corner for sides shorter than 8 inches (see attached image). It's the essentially same rule as this year's, but it would have stopped most of the BUMPER questions this season.
  #37   Spotlight this post!
Unread 26-02-2016, 08:54
OK, time for part 2 for those of you at your first event this weekend.
1. Pneumatics. Not much has changed here from previous years although there are a number of new devices that people will be using. Please remember that all pneumatic parts must be COTS in an unmodified state (except certain exclusions listed in R76). That means no painting!
2. You may not make your own pneumatic parts. That means you may not make an extendable arm using pressure inside a PVC pipe. While it maight be cool, it does not meet the rules.
3. One and only one compressor under RoboRio control. I know you think you have ways around this rule because "air is air". There is no way around this rule. The compressor can be on the robot or it can be off the robot. You can't charge your robot with one compressor and then have another compressor on the robot for the match. No shop compressors charging the system, no exceptions. No FRC legal compressor being run directly from a robot battery while you are in the queue to pre-charge your robot. No larger volume compressor being run from a car battery.
4. The tubing you use must be 0.160" maximum inside diameter. This is not a safety item, this is part of the restriction on max available power. Inspectors are being trained on how to recognize the larger tubing.
5. If you use pneumatics there are certain items that must be present. One of those is a Nason pressure switch, P/N SM-2B-115R/443. No others are allowed and this must not be modified in any way. (They aren't adjustable anyway)
6. When using pneumatics, you must have a calibrated Pressure relief valve connected via legal rigid fittings (e.g. brass, nylon, etc.). A calibrated valve will release air when the system stored pressure is above ~125 psi. These are very easy to calibrate, it requires two wrenches and an alligator clip. Loosen the locking ring on the valve (that is the little hex nut closest to the threaded portion of the valve). Short the pressure switch terminals with the clip and enable the robot. The compressor will run continuously. There is a small hole at the top of the valve. When system pressure reaches 125 psi, some air should be released from the small hole. If no air is present, turn the top hex fitting counter clockwise until air is released. If air is released at less than 125 psi, then turn the hex fitting clockwise to stop the release of air at less than 125 psi. When calibrated, hold the top hex fitting and tighten the locking nut. This is not a precise or repeatable calibration. A correctly calibrated valve will release air between 125 and 130 psi on a repeatable basis.
7. No White Clippard tanks P/N: AVT-PP-41). If you found tanks in your robot inventory and don't know if they are these tanks, just believe they are and get rid of them. The explosion hazard is well documented.
8. "Three way valves" are now legal. these are typically known as one way valves in that air moves in one direction and when released, the pressure flows through a third port to atmosphere.
9. Compressors get hot.Do not place wiring near the compressor be careful to keep pneumatic tubing away from the hot parts as well. Tubing will swell and then fail (with a loud pop) when heated and pressurized.
10. Don't modify pneumatic parts. I am restating this so you don't paint them, obscure part numbers, make scratches, dents or drill into them. You may not drill "lightening" holes in any pneumatic part. Do not drill out and tap cylinders to accept larger fittings. Do not add mounting holes and do not try to modify manifolds to get one more output port.
  #38   Spotlight this post!
Unread 26-02-2016, 09:53
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Al,
Thanks for all your hard volunteer work for FRC!
I may have found a discrepancy in the Inspection Sheet regarding the Driver Station Number. The IS says 16.0.2 but the NI website only shows 16.1.0.
I am not in front on the control system at home so I cannot compare the numbers on the Driver Station but these don't look right.
I will attach a pdf.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
  #39   Spotlight this post!
Unread 26-02-2016, 09:58
The current version that will show on the Driver Station is 16.0.2
So that's what you will compare to when inspecting.
The label on the NI download is incorrect, but is the latest 16.0.2 version.
  #40   Spotlight this post!
Unread 26-02-2016, 10:03
marccenter's Avatar
Mark,
Thanks for checking up on this so quickly.
Marc Center
  #41   Spotlight this post!
Unread 26-02-2016, 10:12
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Al could you comment on regulators? For the primary regulator
R77 I. Pressure regulators with a maximum outlet pressure of no more than 60 psi.
R82 “Working” air pressure on the ROBOT must be no greater than 60 psi and must be provided
through a single primary adjustable, relieving, pressure regulator.
(blue box)Norgren regulator P/N: R07-100-RNEA or Monnier P/N: 101-3002-1
recommended. (Blue Box)
Does that mean A)don't adjust the working pressure higher than 60 PSI or B) regulator capable of being set higher than 60 PSI are not legal. Keep in mind the KOP recommended regulator fits in group A but not group B.
This post is also relevant to the question.
As always thanks for you input.
  #42   Spotlight this post!
Unread 26-02-2016, 10:35
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Am I correct in my understanding that this valve or this valve meets those requirements?
  #43   Spotlight this post!
Unread 26-02-2016, 11:12
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Originally Posted by marccenter View Post
Al,
Just to further clarify... Although the download from NI is named FRCUpdateSuite_2016.1.0.zip, once installed the software identifies itself as version 16.0.2 if you look at the display on the driver station.
  #44   Spotlight this post!
Unread 26-02-2016, 11:23
Marc,
The Inspection Checklist was updated when the software changed to be compatible.
Justin,
I believe those are the valves which prompted this change in the rules. Provided that they do not violate any other robot rules.
Although this is not an FRC endorsement, simply my opinion. The product line you point to from Automation Direct has some pretty cool stuff in it.
  #45   Spotlight this post!
Unread 02-03-2016, 16:43
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
AM now sells other white air tanks, but does not mention whether they are Clippard. Is it ONLY the P/N AVT-PP-41 tank (which I believe is labeled as such) that is illegal?
