Go to Post The answer doesn't lie with an all student run team, or an Engineer-fest team... But somewhere in the middle. Moderation is key. - Cody Carey [more]
Unread 25-02-2016, 19:10
schleprock's Avatar
schleprock schleprock is offline
Code Jockey
FRC #4905 (AndromedaOne)
schleprock is an unknown quantity at this point
Exclamation robotbuilder overwrites parameters on commands that have parameters
i really like the new addition to commands in robotbuilder that supports parameters. the only problem is that when the kids regenerate the Java code, robotbuilder deletes the arguments in the constructor calls in OI.java that puts command buttons on the dashboard. for example we have a command:
TurnRobotWithGyro that takes a parameter: headingDegrees
in OI.java the robotbuilder generates the following for the dashboard button:
SmartDashboard.putData("TurnRobotWithGyro", new TurnRobotWithGyro());
we then add an argument:
SmartDashboard.putData("TurnRobotWithGyro", new TurnRobotWithGyro(90));
if we regenerate the code using robotbuilder, robotbuilder deletes the '90' in the constructor call. for commands that take parameters, i would very much like robotbuilder to ignore whatever is in the argument list when it regenerates the code.
Unread 26-02-2016, 19:29
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: robotbuilder overwrites parameters on commands that have parameters
RobotBuilder will create a button on the SmartDashboard for every preset for every command. So if you have a preset called 'Turn 90' that sets the parameter to 90, it will generate a button for that. It sounds like you're not creating any presets, or even setting the command to take parameters (it only generates a parameterless button on the SD if the command itself hasn't been set up to take parameters). I think it would be good to take a closer look at the Robotbuilder documentation.
WPILib
GRIP, RobotBuilder
