Go to Post Mind you... if your ball kicker has as much energy stored up as a trackball launcher, you ought to be able to kick balls up into the stands. - dtengineering [more]
Unread 31-03-2003, 21:14
Matt McNelley Matt McNelley is offline
#0016 (Baxter Bomb Squad)
Matt McNelley is an unknown quantity at this point
Failure of Robot Interface
Anyone who saw our first round of the finals at the Midwest Regional knows that we didn't function at all after sustaining an impact from another robot. It was thought at first that it was a battery problem, and that is what you heard from the announcer if you watched the webcast, or were there. Well, the problem was not a battery connection, or any other kind of external connection for that matter. Immediately following the round, we gave all the connections a thorough inspection, and could find nothing wrong with the robot. We were still getting power, but we had no radio communication. Well, one of the engineers gave the console a couple of taps and it came back to life. Something inside of the actual component of the radio equipment must have broken. Whatever it was, it definitely didn't help us out any.
Has anyone else had problems of this sort?
-Matt
Team #16
The Baxter Bomb Squad
Unread 31-03-2003, 21:21
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
we can't run the robot in tether mode. it doesn't supply a constant current to the OI. no idea how/when it happened, but it doesn't work now. radio on the other hand works fine.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 31-03-2003, 21:31
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
ACK!!!!
Greg and I got pretty mad in our 2nd qualifying match. We put our robot out, set autonomous, and had the controller set up correctly. We were getting a valid signal and weren't disabled. Autonomous started and the robot didn't move but light turned on. During human control period, nothing responded even though the OI said we were getting a signal and not disabled.
We tested the robot after the match and it was fine. Next match, our robot ran perfectly without any changes except changing a constant for amount of turn in autonomous. That weird and it did not seem at all our fault that nothing worked.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 31-03-2003, 21:43
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
I heard that 1064 found that if you shake the modem it can cause your controller to reset...seems that there might be some quality problems this year in the control systems.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 01-04-2003, 00:09
Hey! Hold on there for a second. Let's not blame the controller or the modem until we know for sure. There was a number of teams we found running radio, not tether in the pits. This has occurred at every event for the last two years that we have attended. Although it is claimed that there is no interference when this would occur, I am not yet convinced that some interference might be possible. It might not be data but it might be RF intermod. We are still looking into this and will pursue it with Innovation First in two weeks.
Baxter took a very hard hit in that match. We have had more than once, a broken pico fuse holder on the controller. It is possible that this might be why it began working after some tapping on the case.
It is common to try and get a long tether to allow you to drive while not using the modem. Cheaper, small diameter serial cables have significant loss of both DC and signal. If you were using anything longer than a 10' cable suspect that the cable is at fault.
Unread 01-04-2003, 00:38
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
1064's controller problems
Team 1064 did indeed experience problems in St. Louis with our modem. We had lost communication in a couple of matches and could not figure out what had happened. The basic error light came on and it was fixed with the reset button, but it was still a problem. So we looked over everything in the pit and upon instruction from the head Innovation First guy, took it to the back of the arena and powerd up via radio. We found no problems at first, but when an engineer from team 71 that was helping us find the problem shook the model around a bit, we experienced the problem we had on the field.
The strange part about this is that in Chicago, with the same modem (new cable that got replaced in St. Louis), we experienced no problems whatsoever. We took harder shots in Chicago than in St. Louis too. So I'm not really sure what happened there. Maybe we passed our misfortune on to you guys somehow. Hope it is fixed for you before Houston. Good luck there!
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 01-04-2003, 04:02
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Re: Failure of Robot Interface
We had some similar and very weird problems last year where we would suddenly loose connection while at our school. Once we changed a fuse near the modem port and the problem went away, so we thought we had solved it.
Then just prior to the Summer Classic last summer, we had the same problem again and changing the fuse did nothing.
We then did a major rewire job with a different circuit breaker panel, and once again all went well.
Later, we had the same problem again. An additional symptom that appeared and seemed related was that our robot sometimes did strange random things, motors twitched off and on, the light went on and off, and these things occurred repeatedly and together. More than once, we had a cyclical connecting/ disconnecting occurring with the light going off and then on again every second or two, while the motors activated and deactivated. We also had the no data light turning on. It seemed like our robot was betwitched.
We tried a lot of different things to try to handle it. Finally we changed out the radio on the operator interface and since then no problem. This time, the solution seemed to be clear in our case, in that the problem kept occurring and then the second the radio was changed, it was gone and never came back. (We had tried tightening the connections from the radio to the operator interface and changing the radio wire, with no success.)
Hope the data helps in some way.
Good luck guys. I know it is not fun, especially during the finals of a competition.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 01-04-2003, 08:06
ldwalls ldwalls is offline
#0519 (Robomasters)
ldwalls is an unknown quantity at this point
Cool
We had that happen the day we shipped the Robot. We came to the conclusion that it was a loose connection. It had all the symptoms you listed. But we have been in some tough battles since (one of our PWMs' was destroyed) but the interface has been rock steady since.
Unread 01-04-2003, 20:23
marlon_jbt's Avatar
marlon_jbt marlon_jbt is offline
FIRST IS LIFE... 4 years later too!
FRC #3322
marlon_jbt is an unknown quantity at this point
Send a message via AIM to marlon_jbt Send a message via Yahoo to marlon_jbt
Robot Controller
Well, our Robot Controller is pretty much out of the way from all impact, and is VERY PROTECTED.
I don't think we will have any problems with it, since it's well mounted deep inside... (My idea, hehe, me a smart person!)
Funny, "I" and the rest of the team thought the PWM Cable was destroyed because of hole drilling...
|l ,[____],
l---L –OlllllllO-
()_) ()_)----)_)
Unread 01-04-2003, 20:33
Chris Nowak Chris Nowak is offline
Soudeska?
#0074
Chris Nowak is an unknown quantity at this point
Our operator interface had to be sent back a week before our first competition because the LED display suddenly stopped working. And while I cant remember why it wasnt working, it wasnt our fault, it was some defect or something. The OI was still functional, but most of the LEDs and the team number/voltage display was either really dim or totally off. I think we ended up having some problems when we got the OI back, but I cant really remember.
MSN Messenger - chris_nowak91@hotmail.com
Team 74 - Top Seeded Team in Galileo Division
Unread 01-04-2003, 20:39
dhendrix's Avatar
dhendrix dhendrix is offline
#0538 (Dragon Slayers)
dhendrix is an unknown quantity at this point
Team 538 had alot of problems with our radio in St. Louis also. We first blamed it on First, They were having alot of problems with there equipment. I looked for anyone running off tether,
but found nothing. We did however find a few people using 2 way radios. We had no more trouble the next day, but I find it strange that we where dead the whole match, no light, no nothing. We replace the O/I with a loner from FIRST, and did not
have any more problems. Just in case.
Unread 01-04-2003, 21:32
Lindsey Lindsey is offline
Lindsey will become famous soon enough
Team 548 had the exact same problem at Great Lakes, our problems were solved when we tethered our robot and plugged the OI into the wall. I don't remember exactly but one of our electrical engineer explained the problem, something like there wasn't enough power to run the robot and the OI so the robot got first priority and the OI went below sufficient running voltage and kept reseting.
Hope this answerer the question if anyone wants a more detailed explanation let me know and I'll talk to the engineer.
Lindsey
Unread 01-04-2003, 21:40
Kojib Kojib is offline
Kojib is an unknown quantity at this point
Send a message via ICQ to Kojib Send a message via AIM to Kojib Send a message via Yahoo to Kojib
Hey there. I feel a little out of place as I generally stay away from the electronics part of our robot and work on the mechanical aspects of it. Keep this in mind as I continue with my guesswork. Basically, Two Minute Warning takes several really, really, really rough hits in final rounds in Chicago (We actually had both of our wings bent. That's right, 20 mm extruded aluminum bent.) After a few hits like this, we take a really, really hard one at the end of our autonomous mode. When human control starts we have no radio contact. In my head, what has happened is a circuit board or something couldn't take the hit and shaked or a wire inside bent or something, resulting in it reseting or something to that matter (I told you I tend to stay away from controls stuff). In order to keep this from happening in the future, could I simply either get some foam or rubber gromets to act as shock absorbers between the radio controller and the frame of the robot? If you respond to my question, please explain as much as you can, either what actually happened or what might fix it in the future. Thanks
Unread 01-04-2003, 22:48
Robot-A-Holic
Lindsey
We had our tether port toward the front of the robot, and while driving the 'bot on tether, a person stepped on the tether which yanked the tether port back and damaged it. After a few days, the tether port didn't work.
We had to send the robot controller back for repairs. In the meantime, Innovation FIRST upgraded our last year's robot controller to this year's specs for about $40, and we used it.
Unread 01-04-2003, 22:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We had the controller in near the front of our robot and the radio cable plug stuck out about 1/2 inch past the chassis. Well, on our first run we ran it into a pole in our room and it just so happened that it hit right where the plug was and pushed it up breaking a few of the pins. It still worked fine but we did not want to take the risk so we opened it up, took out the port and replaced it with a new one. This voided the warranty but the warranty only covered factory defects anyway so there was nothing to lose. Today, you would never know that we broke it. And the best part is that my brother (electronics/electrical expert) had it all fixed before the engineers got back.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
White Paper Discuss: EDU Robot Controller PC Interface CD47-Bot Extra Discussion 4 24-11-2003 10:01
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
how do u connect the battery to the robot interface? chrisw Technical Discussion 1 10-01-2002 16:41
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
