Go to Post But that deals with quantum phys-- ooh, shiny objects. - Otaku [more]
Unread 25-02-2016, 13:22
carrud carrud is offline
AKA: Clark Rudder
FRC #2637
carrud is an unknown quantity at this point
Comm / No Comm; Little Consistency
Frequently getting no communications to robot.
Windows 10
Eclipse c++
I’m running all current FRC software versions as far as I could double-check.
It is sporadic, but I can reproduce the following:
-Booting everything up, I get comm fine.
-Power off / on the Robot.
-Reconnect laptop to the robot network
-DS gets no comm
-I can http to both the router and the roboRIO
-I stop / start the DS
-DS gets no comm
-I reboot the laptop
-DS gets comm just fine.
When DS has green comm, If is disconnect the wireless network, then reconnect the network the DS comm stays red.
What’s going on??
Many Thanks
Unread 25-02-2016, 14:34
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Comm / No Comm; Little Consistency
Have you tried turning off the Windows firewall? Also, we switched our roboRio to a static IP to avoid mDNS issues. We put an entry for roboRIO-####-FRC.local into the development pc's hosts file. (replace #### with your team number). We will probably set our driver station to a static IP too for competition. The static IP was mainly so MAC and Linux computers could connect to it easily.
Brian K
Team 1225 Robotics Mentor
Unread 25-02-2016, 15:03
AKA: Clark Rudder
FRC #2637
(I tried turning off Firewalls, no change)
I found the following. The reason I loose comm is because the mDNS fails to resolve.
- After rebooting laptop I get green comm
- DS, Eclipse, and Internet Explorer can resolve roboRIO-2637-FRC.local
- On laptop I disconnect from the robot network.
- On laptop I retconned to the robot network.
- At this point roboRIO-2637-FRC.local is not being resolved by Eclipse or Internet Explorer, and I expect that is the problem with the DS.
So it is mDNS?
Unread 25-02-2016, 15:22
SuperBK's Avatar
AKA: BrianK
If you shift-click (or maybe just click) the down arrow next to the team number in the driver's station, that causes a new mDNS query to go out. See if there is anything listed there when it can't communicate. It should be all robot names detected on the network.
mDNS has caused issues in the past for us. That's why we switched to static. We think we know the ramifications of it.
Brian K
Unread 25-02-2016, 15:29
AKA: Clark Rudder
FRC #2637
The "click the down arrow" thing had no effect.
Unread 25-02-2016, 19:43
In a command window try:
ipconfig /flushdns
Unread 25-02-2016, 22:43
Disable IPv6? It's voodoo, but I've seen it help.
Unread 01-03-2016, 00:24
AKA: Clark Rudder
FRC #2637
Hacked at this for days and could not find a fix for the root cause. I have circumvented this by moving to static IP on the roboRIO.
-Clark
Unread 01-03-2016, 07:13
Windows 10 has some non-compliant mDNS behavior.
For other people with Windows 10 installations just Disabling/Enabling the network connection has worked.
Unread 01-03-2016, 09:03
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Its really weird, the only way we have been able to connect to the new bridge wirelessly is by connecting via usb, wait until we have comms, connect to the bridge wirelessly, then disconnect the USB. Its really strange.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 01-03-2016, 09:58
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
While this is bad advice for computers in general, If you are able to devote a computer to be your driver station...
Disable all automatic updates. Keep non DS specific software off the computer. Disable start up auto loaders for software that is installed on the computer. Only connect to the internet when required to download software or updates. Turn off the firewall. Try disabling the Ethernet adapters you are not using. Don't let the programmers watch little pony or cat videos on the DS computer.
