Go to Post [in best Tom Hanks voice] Are you crying? ARE YOU CRYING? There's no crying! THERE'S NO CRYING IN ROBOTICS! - dlavery [more]
Unread 02-26-2016, 01:53 PM
jabarabara's Avatar
jabarabara jabarabara is offline
FRC #2415 (WiredCats)
jabarabara is an unknown quantity at this point
Problems with Morphology
So, in the past week I've been working on computer vision for this year's competition. I was able to create a binary image by thresholding an image for HSV ranges, but when I try to use morphology dilation I get an error
        NIVision.Image img, bin, morph;
	NIVision.RawData colorTable;
	final NIVision.Range HUE_RANGE = new NIVision.Range(213,255);
	final NIVision.Range SAT_RANGE = new NIVision.Range(217,255);
	final NIVision.Range VIS_RANGE = new NIVision.Range(102,204);
        public void robotInit() {
    	    	img = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_RGB, 0);
    	    	bin = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_U8, 0);
    	    	morph = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_U8, 0);
    	    	colorTable = new NIVision.RawData();
        public void operatorControl() {
    	    	NIVision.imaqReadFile(img, "/home/lvuser/capture.jpg");
    	    	NIVision.imaqColorThreshold(bin, img, 255, NIVision.ColorMode.HSV, HUE_RANGE, SAT_RANGE, VIS_RANGE);
    	    	NIVision.imaqWriteJPEGFile(bin, "/home/lvuser/bin.jpg", 2000, colorTable);
    	    	NIVision.imaqMorphology(morph, bin, NIVision.MorphologyMethod.DILATE, new NIVision.StructuringElement(3,3,1));
    	    	NIVision.imaqWriteJPEGFile(morph, "/home/lvuser/morph.jpg", 2000, colorTable);
I got this error from the code above:
VisionException [com.ni.vision.VisionException: imaqError: -1232673104: Unknown error]
	at com.ni.vision.NIVision._imaqMorphology(Native Method)
	at com.ni.vision.NIVision.imaqMorphology(NIVision.java:24502)
	at org.usfirst.frc.team2415.robot.Robot.operatorControl(Robot.java:47)
	at edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:159)
	at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:242)
I've already tried searching for the problem to find a solution and couldn't. I don't see what's wrong. Any ideas?
Unread 02-26-2016, 02:04 PM
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Re: Problems with Morphology
Is there any particular reason you're using NIVision instead of OpenCV?
Unread 02-26-2016, 02:10 PM
Ozuru's Avatar
Originally Posted by jabarabara View Post
I tried OpenCV at first, but I could never get the code to load the library .
I highly recommend using OpenCV over NIVision.
Also, to load the library:
    static {
	System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
Unread 02-26-2016, 02:15 PM
jabarabara's Avatar
    static {
I'll try and see if I it will load then and get back to you.
P.S.: sorry for deleting my earlier message. I was trying to rewrite it as a reply to your post, not just another post. Still new
Unread 02-26-2016, 02:17 PM
Ozuru's Avatar
No problem. I recommend trying to use OpenCV. If you're new to vision tracking, 341's 2012 vision code is required reading: http://www.chiefdelphi.com/media/papers/2676
Unread 02-26-2016, 07:10 PM
jabarabara's Avatar
Okay, so now I've tried your methon and I get:
java.lang.UnsatisfiedLinkError: no opencv_java310 in java.library.path
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1857)
	at java.lang.Runtime.loadLibrary0(Runtime.java:870)
	at java.lang.System.loadLibrary(System.java:1119)
	at org.usfirst.frc.team2415.robot.Robot.<clinit>(Robot.java:13)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:259)
	at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:204)
with this as code (added the try catch after the first time it failed to get error printed neatly):
import org.opencv.core.Core;
import edu.wpi.first.wpilibj.SampleRobot;
public class Robot extends SampleRobot {
	static{
		try{
		}catch(UnsatisfiedLinkError e){
			e.printStackTrace();
    public void robotInit() {}
    public void autonomous() {}
    public void operatorControl() {}
    public void test() {}
I tried putting the .so file for opencv in the same directory as the FRCUserProgram on the roboRio, and it still returns this error.
Unread 02-26-2016, 07:18 PM
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Since you know exactly where the opencv library is located, you have the option of calling System.load("/path/to/library"). Also, make sure that the file is named "libopencv_java310.so", or System.loadLibrary() won't be able to find it.
Unread 02-26-2016, 07:55 PM
jabarabara's Avatar
Okay I figured out the problem.
1) I didn't have all the necessary dependencies in the directory of the opencv_java"version".so
2) Beforehand, I placed the files in a "/usr/local/lib," and it turns out that I don't have the necessary permissions to load the library from there. Moving the library and its dependencies to the directory of FRCUserProgram.jar fixed that.
I now have OpenCV running on the roboRIO, so I can finally continue Vision Processsing. Thanks for all the help everyone!!!!
Unread 02-26-2016, 10:07 PM
Ozuru's Avatar
Great progress!
I suggest you do not do vision processing on your roboRIO itself. The processing will cause stuttering on your robot's end. I highly recommend sending the frame to the driver's station and then doing processing there in a stand-alone application.
Unread 02-27-2016, 05:35 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Running vision on the DS laptop will result in huge delay times (obviously). We are running vision on-board in a separate thread and it seems to work fine (main robot loop still runs at 50x/sec)
