Go to Post wait a minute...Dave posted a hint here yesterday. but no one has tried to analyze it word by word. has something changed since the kickoff??? - jerry w [more]
Unread 26-02-2016, 13:14
pagemauck pagemauck is offline
pagemauck is an unknown quantity at this point
Eclipse C++ 2015 updating to 2016 toolchain
We are stuck - had no problems with 2015 code - building - deploying - no problem.
Trying to update to 2016 has been a nightmare!
We would like to use Luna and simply update to the 2016 toolchain - but are getting error source\robot.o: no such file or directory after updating. With one week until competition I am a bit worried!!!
I have attached error file - thanks!
File Type: txt errors2.txt (395 Bytes, 9 views)
Unread 26-02-2016, 14:03
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Eclipse C++ 2015 updating to 2016 toolchain
Run a Build Clean (Project menu) then build again. See if that works.
Unread 26-02-2016, 15:27
ghead ghead is offline
FRC #3103
ghead is an unknown quantity at this point
I don't see any includes listed in the file you posted, and I believe they are generally part of that output. Might want to visit Properties->C++ Build->Settings and look under 'Cross G++ Compiler' at the 'includes' section and make sure everything looks right.
Should have at least two entries I think, one that points to your project and the other to the WPILIB includes directory. All this should be setup during install of the plugins/toolchain.
Unread 27-02-2016, 10:58
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
I tried to update in place and it didn't work out right.
I recommend starting with a new clean Eclipse folder and reinstall the toolchain and plugins. Rename the old folder and unzip Eclipse to a clean empty folder. Be sure to run the toolchain installer from the drive you want it installed on. Then put the plugins in using the online method. You can use the same workspace, or import the needed projects into a new workspace.
Brian K
Team 1225 Robotics Mentor
