Go to Post First and foremost, teach which end is the hot one on a soldering iron. - Al Skierkiewicz [more]
Unread 02-27-2016, 10:15 AM
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: Permission denied when pushing code
Originally Posted by Joe Ross View Post
In eclipse, go to help->installation details and select Robot C++ Development (and Java if it's also installed), and press uninstall. Then, for good measure, delete c:\users\<user>\wpilib
Just a rebuild.
Last wpilib release was 2/11. I did see an eclipse update today.
Done, thanks. I have reinstalled wpilib and rebuilt my project, and I will go into the school shortly to try it out. Any ideas on what to do if the problem persists?
Also, any thoughts on how I might have altered the build configuration files? I did play around in there but only after the original problem popped up and I searched for threads on this problem on CD.
FYI, I did add very basic navX MXP stuff to the include and library settings early yesterday, before the issue, but I followed the instructions on their site. I will refrain from doing any of that until I can deploy code again. I'll save the project and then play.
Unread 02-27-2016, 11:51 AM
O-H
Just for fun, I got the roboRIO off our 2015 competition robot, updated the firmware and imaged it EXACTLY per the instructions (i.e. how I did everything before), and I'm still getting permission denied error. This time, however, it seems to proceed to the "kill all" part of the deploy routine before faulting. See attached, updated screenshot.
Please keep the suggestions coming - I'm at the school all day today and can try anything out quickly. Obviously, this is a problem that needs solving ASAP.
Name:	2-27-16 Deploy Error.jpg
Last edited by Travis Hoffman : 02-27-2016 at 01:30 PM. Reason: Updated information.
Unread 02-27-2016, 03:33 PM
O-H
I just installed Eclipse et al on another laptop and used some old version of my code that worked prior to this problem, and the permission denied error occurred on deploy exactly as before.
Still hoping for some good ideas here from the community!
Unread 02-27-2016, 08:49 PM
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
This popped for us today, any ideas?
Brian K
Team 1225 Robotics Mentor
Unread 02-27-2016, 09:22 PM
O-H
I just got ours to work...but I don't really know what I did.
I reflashed firmware and reimaged the roboRIO multiple times using our driver station Classmate and my programming laptop. No dice.
I swapped the roboRIO with another one - no dice. Same problem.
I got a completely different laptop, updated the WPI plugins, tried to deploy, no dice.
I used the same laptop to reflash and reimage the roboRIO. I deleted the project from the workspace, then reimported it and rebuilt. At this point, it downloaded. I am not even sure that action contributed to the fix.
Unread 02-28-2016, 02:51 AM
O-H
Anyone experiencing problems, please cross-post details to the FIRST Forums thread here - http://forums.usfirst.org/showthread...-During-Deploy.
Time to make it loud.
Unread 02-28-2016, 10:54 AM
AKA: Brad
#0190 ( Gompei and the Herd)
If you're familiar with Linux, could you try ssh-ing to the roboRIO as lvuser and check the permissions and ownership of files in the lvuser home directory and look for anything not owned by lvuser. It seems like somehow something is getting messed up, maybe a a download failing part way through or something.
If not, I would expect that reimaging and being sure to check the reformat box in the imaging tool would get you back. If you do that, be sure to reinstall Java if that's the language you're using.
Brad
Brad Miller
Robotics Resource Center
Unread 02-28-2016, 10:31 PM
carrud carrud is offline
AKA: Clark Rudder
FRC #2637
carrud is an unknown quantity at this point
This partially worked for me. This exact placement did not resolve the Permission Denied, but moving the line to a diff spot in the .xml worked great.
BTW, for others: this .xml for me is in wpilib/cpp/current/ant
Many thanks for posting this fix.
-Clark
Unread 02-29-2016, 03:06 PM
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
I am now getting the Permission Denied feature when trying to deploy. Started today after I allowed eclipse to upgrade from 4.5.1.20150917-1200 to 4.5.1.20160218-0600.
I Tried "reverting" back in Eclipse.
I tried using FileZilla to allow all permissions to home/lvuser. My changes did not seem to stick.
I tried changing changing build.xml that is ..wpilib\cpp\current\ant adding:
<sshexec host="${target}" command="chmod 777 /home/lvuser" failonerror="false" trust="true" password="${password}" username="admin"/>
at random locations.
I tried updating the firmware in the roboRio.
I did not feel comfortable that I did any of the above steps correctly, but I am still unable to deploy code.
I will try deploying with another computer this afternoon.
Unread 02-29-2016, 04:11 PM
SuperBK's Avatar
AKA: BrianK
You may have to ssh to your roboRio first and issue the "chmod 777 /home/lvuser" to give permission to the folder, then run the modified build.xml. . After issuing the command you can do
ls -l /home/lvuser
and see if the permissions are "drwxrwxrwx" to see if your changes take.
Do you need step-by-step instructions on how to ssh to it? I use putty, a ssh client.
After doing that, try deploying again. Post the entire contents of your build log here.
Do you see se the extra chmod command in your build log?
Add exactly this (cut and paste)
username="admin"
trust="true"
failonerror="false"
command="chmod 777 /home/lvuser"/>
Above the line
<scp file="${wpilib.ant.dir}/robotCommand" todir="${username}@${target}:/home/lvuser/" password="${password}" trust="true"/>
Brian K
Unread 02-29-2016, 05:16 PM
AKA: rod nelson
Thanx Brian,
When I had previously tried to set permissions with filezilla, I had logged on as lvuser. It probably did not the right privileges. Logged on as admin and the permission changes stuck.
Added your "chmod 777" to build.xml and voila.
You will be receiving good karma credits.
Unread 02-29-2016, 05:39 PM
O-H
I THINK THIS IS KEY. The computer that works and deploys code has MARS.1 installed (4.5.1.20150917-1200). The computer that started flaking out and throwing permission denied errors has MARS.2 (4.5.1.20160218-0600), which I installed shortly prior to this problem occurring.
I will use the build.xml hack in an emergency, but I hope the developers investigate this potential blar with Eclipse developers.
Unread 03-01-2016, 12:53 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
We're seeing this same issue here at 116. I wiped out the updated Mars.1 eclipse and installed Mars.2 with the exact same results -- permission denied. I still have the original Mars.1 install package. I'll try that, but I suspect that it will work until the update rolls in.
Mike A.
FRC #116
Unread 03-01-2016, 01:13 PM
SuperBK's Avatar
AKA: BrianK
I did put on updates and after that the error occurred. I thought it was just WPI plugins, but it looks like at some point between Feb 13 and Feb 29, the update also updated Eclipse to 4.5.2 4.5.2.20160218-0600
Brian K
Unread 03-01-2016, 02:10 PM
Astropolly Astropolly is offline
FRC #1138
Astropolly is an unknown quantity at this point
I'm having the same problem. Everything worked previously when I had Mars 1 installed. Now I have Mars 2 and I can't deploy code. I can't actually say if that is the problem though.
I used PuTTY to ssh into the roboRIO, and I used the chmod command as explained on these threads. I then tried to deploy code - without resetting anything, but I got the error
..\wpilib.cpp\current\ant\buil.xml:78: server indicted an error: scp: /home/lvuser//robotCommand: Permission denied .
the results of the ls -lah /home/lvuser/ command show
admin@roboRIO-1138-FRC:~# ls -lah /home/lvuser/
total 10292
drw-r--r-- 4 lvuser ni 656 Mar 1 10:39 .
drwxr-xr-x 5 admin administ 416 Jun 5 2015 ..
-rwxrwxrwx 1 lvuser ni 410 Apr 30 2015 .bashrc
-rwxrwxrwx 1 lvuser ni 152 Apr 30 2015 .profile
-rw-r--r-- 1 lvuser ni 10.0M Mar 1 10:39 FRCUserProgram
lrwxrwxrwx 1 admin ni 42 Dec 17 10:34 FRC_UserProgram.log -> /var/local/natinst/log/FRC_UserProgram.log
lrwxrwxrwx 1 admin ni 22 Dec 17 10:31 README_File_Paths.txt -> /README_File_Paths.txt
drwxrwxrwx 3 lvuser ni 232 Dec 17 10:34 frc
drwxrwxrwx 4 lvuser ni 296 Dec 17 10:35 natinst
I will try making the changes to the build.xml file, but I was expecting this to work at least the first time
I am so lost. Please help
