Go to Post If the world was like ChiefDelphi, people would be more eager to help out, offer advice and encourage each other to better things... not a bad world, that. - MissInformation [more]
Unread 27-02-2016, 11:21
Re: Static IPs on the field
Originally Posted by cbf View Post
People -- the OpenMesh OM5P-AN radio can run a DHCP server. Enable it!
Then set a DHCP reservation to put your Robrio at the .2 address (e.g. for us that's 10.28.77.2). Set a reservation for your IP camera, if you have one (I think the old convention was the use the .5 address for the camera, or was it .11?). The OM5P-AN should be at the .1 address of course.
This is much better than statically assigned addresses because you don't have to worry about manually changing the Robrio, drive laptop, and/or camera back and forth between static and dynamic address assignment when you're testing, or at the competition -- or simply moving the laptop connection from the robot to your local WiFi because you to look something up on the Internet.
This will not work at the event. Your radio will be programmed with a password by the radio kiosk at the event and you won't be able to enable the DHCP server.
