Alternative to the PDP and VRM
As a second year team we are short on resources and only have one PDP and VRM that we reused this year for Stronghold (it is in the bag). I am looking to make last year's chassis drive-able and looking for a cheap alternative to buying a new PDP and VRM.
My plan involves a marine supply fuse box that fits the "MAXI" 40A fuses, any other alternatives out there that teams have used? I am still trying to figure out how to power the Roborio safely any ideas. "Power Requirements The NI roboRIO requires a power supply connected to the power connector. Power supply voltage range 7 VDC to 16 VDC Power Consumption Maximum 45 W Typical idle 5 W" Thanks for your ideas! |
Re: Alternative to the PDP and VRM
If you can get a hold of one of the old Power Distribution Boards that is the easiest swap. Powering the RoboRIO isn't hard since it is designed to just take battery voltage. Just put a small fuse inline with it before wiring it to the battery. A MAXI style fuse panel will work for your motors as well like you suggest.
Note that if you're using CAN for anything (other than your non-existent PDP) you'll need a 120ohm termination resistor at the end of your chain to stand in for the missing PDP.
I assume you are also using the old radio and you need (or already have) a source of 5V and ~2A.
If you ask around teams in your area, someone will probably loan/give you a 12V to 5V converter that used to be required for the radio, due original radio being 12V. It looks like this one (common style): http://www.amazon.com/RioRand-Waterp...dp/B00JM07LMY/ AndyMark and others sell this one: http://www.andymark.com/product-p/am-3068.htm ServoCity has this Step up/Step down one: https://www.servocity.com/html/5v_st...l#.VtE1M5wrI1I I haven't used either of the last 2 products, but I probably am going to buy the last one (if I can't find a similar higher amp one) to power some cameras rather than a 2nd VRM. Of course, you could always make your own circuit with parts you might already have. |
There are cheap PDB for the cRIO on eBay right now.
We are in a very similar situation. However we are trying to power a PCM and RoboRIO using one of the old PDBs, as well a (hopefully) the new radio. Only catch is that we don't have a spare VRM.
Is there any downside to powering the roboRIO directly from the 12V output on the PDB? How about the PCM? |
#7
It's fine to run off the 12v output with a small value breaker.
#8
Thanks for all the input, we went with a Marine supply breaker for the snap action fuses (6 on a panel) ~75$, and for the VRM we took a cell phone car adapter USB connector ~6$ and soldered onto the converter inside it takes 12V in and puts out 5V 2A. All up and running now.
Thanks again |
#9
Hi,
Klhutchi our team is in New York, we should have some older pbd's knocking around the lab. Message me privately if you still need one. Karl |
#10
The only downside it you have no 'brownout' protection. If battery voltage does not fall too much you will be fine
