Go to Post If we all keep our "secrets" about our robots, the rest of us don't learn as much. - Rick TYler [more]
Unread 27-02-2016, 12:25
addis687 addis687 is offline
no team (Team)
Team Role: Webmaster
addis687 is an unknown quantity at this point
Angry FRC Gazebo Installation Will Not Work
When I try to install the Gazebo package from **wget -O frcsim-installer.sh first.wpi.edu/FRC/roborio/release/frcsim-installer.sh && chmod a+x frcsim-installer.sh && ./frcsim-installer.sh INSTALL** (https://wpilib.screenstepslive.com/s...-script-ubuntu). When I perform this command, I get the "INSTALLATION UNSUCESSFUL" error.
When I try to use the manual installation method, I get errors from the first step (Install OpenJDK from ADT).
Has anyone got this error? What did you do to solve it?
I am running Ubuntu 14.04...
Unread 27-02-2016, 12:54
isaacaddis's Avatar
isaacaddis isaacaddis is offline
FRC #0687
isaacaddis is an unknown quantity at this point
Re: FRC Gazebo Installation Will Not Work
OMG I HAVE THE SAME ERROR. MY TEAM NEEDS THE FRCSIM REALLY BAD
Unread 27-02-2016, 13:04
It would help if you posted more info on what error you get when installing manually.
Unread 27-02-2016, 13:11
isaacaddis's Avatar
FRC #0687
One of the errors: cannot move 'eclipse' to '/opt/eclipse'
(When I try to do to **wget -O eclipse.tar.gz \
http://eclipse.mirror.rafal.ca/techn...-x86_64.tar.gz **)
Unread 27-02-2016, 13:12
Peter Mitrano Peter Mitrano is offline
Peter Mitrano is an unknown quantity at this point
Hello! FRCSim maintiner here. Can you put the *entire* output from running the command?
You can re run the install command and add
> output.txt
to send all the info to a file if that's easier.
The same goes for manual install, what is the *exact* output of the command that fails?
Unread 27-02-2016, 16:42
isaacaddis's Avatar
FRC #0687
Why does this happen? I've been trying to do this for 3 days and I still get this:
Unread 27-02-2016, 17:09
no team (Team)
me too omg
Unread 28-02-2016, 23:25
Well it says you can't access the internet. You need internet to install frcsim.
Are you sure you have internet (does your wifi require a login?)?
